those professors are in MINT condition. beautiful in the flesh.
2k for 18x9.5 & 10 +18 3pc meisters? thats with trade in of my stuff. i rekon i might be able to get cheaper if i shop around
you have to be fair rad to run 18x9.5 professors... :)
Pachelbel's Canon (Canon in D).
Most famous and one of the best classical piece of music ever written.
I totally forgot about that one! I used to play it in a string quartet (at rich people's parties lol). It's awesome!
my fav too. ;)
Good taste Danielle :P
well i got a daily so ill just drive it around.. least i dont have to worry about scratching it.
i dont really worry about scratching mine, its an easy fix when you have friends that do that stuff for a living ;)
Was waiting at the lights last night. Some white VW polo rocks up next to me full of guys. Listening to some doof doof.
We both move off from the lights and the VW begins to do a u-turn. As i pass them, the passenger throws an egg at my car and drive off....
Good thing it was only my rust bucket Hyundai Getz. Washed the car and drove around a bit trying to find them but no luck...
Moral of the story; VW polo's are driven by faggots ;)
does anyone in here like to listen to classical music sometimes?
I must know about 10 of Beethovens Piano Sonata's... love playing that stuff.
Current favs are Bach Cello Suit No.1, makes me want to learn Cello and also playing Gymnopedie No.1 - Erik Satie. <3 <3 <3
Lol some dumb bitch decided to take her stato at epic speeds from springvale rd onto wells rd. Lost control and spun a few time and ended up in a ditch infront of my work. Ambo and coppas came quick enough. Hope she gets charged with reckless driving lol
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
