its up to episode 8 of season 7 now (futurama that is).
wow it is?
i only just got
Futurama.S06E08.That.Darn.Katz.HDTV.XviD-FQM
oh on 2nd look @ wiki page i see that season 4 was split into season 4 and 5! :)
now i understand :)
Damn!
Futurama is up to Season 8?
I got Season 1 to 4 boxsets and the 4 movie length episodes they made...
Lost interest cuz the movie length episodes were not all that good and Family Guy rapes everything!
Family Guy owns!
trying to find a genuine sub 50,000km r34 GTR is such a bitch =/
lol @ trying to find a car that stopped production 8 years ago that averaged 6250km/year at best.
would you like it gladwrapped too princess?
only complete nooblets believe the old myth that people in japan don't drive much.... and if they don't they're old people who can't afford to drive it or own it, but hold on to it, just in case they ever need a car... the kind of people who'd never buy an R34 GTR.
FYI not everyone drives 6000kms a year..
ive done little over 2K this year in my r33. which would mean it should average to be about what 3.8approx (im guessing) total for this year?
sure it might be damn hard to find one
but no reason to be a tool..
one here with full service history
http://www.skylinesaustralia.com/forums/R3...ec-t321233.html
it's not damn hard. it's not possible. instead of worrying about something petty like mileage, maybe put your time and attention into buying a car that is mechanically and structurally sound. god knows how many you've passed up because of your 50,000km criteria. find a car that is from a reputable dealer in jp and have it inspected by a mechanic.
the newest GTR you can get is 8 years old, so expect at least 100,000kms on it. Any less and I'd be sus. In fact the closer it is to 100,000 the cheaper it'll get as people who don't care about their car cbf doing the major service.
lol @ using 1J's car as an example... he's got mad hookups and the patience of a hermit.
ha. do you have a daily? or do you walk everywhere? i'm averaging approx 20k a year on mine
yeah i have a daily but tbh thats only done a bit over 3K this year
I worked over the otherside of melbourne last year and did about 20K
but back to doing some study and walking / public transport aint too bad :P
I didnt really take that into account, I was thinking that most with a lower mileage are going to be less of a hassle mechanically and structurally.
but you make a good point :O
sorry for my ignorance :P
This man, he knows.
DO NOT believe Japanese km's, they're wound back so often. And these wound back cars tend to fetch more at auction and at dealers because people fall for it.
Instead look at the condition of the car, that's far more important.
yeah I suppose if you're buying electronics retail then it works out. lol it's kinda like if I was to go pay retail price for chocolates, you'd be like "lol n00b"
haha, my old man has a jaycar trade card but they only offer discount when spend over $20 :/
Which place you shop at?
agreed, i wouldnt worry about what km's it has id be looking at the condition its in. mine is very close to 100,000km, just got the full service done last week. and the guys said that my car is in great condition, there are no rust spots and mechanically it is fine. only some suspension parts are worn out but i got most of it replaced, im just waiting on the tie rod ends.
look whos back.... whats been happening man
not much... well... probably a lot since i was last on here... cant remember
wtf is with the spider threading?
looks ubery gheysexual
what you been up to?
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
    • @PranK can you elaborate further on the Colorlock Dye? The website has a lot of options. I'm sure you've done all the research. I have old genuine leather seats that I have bought various refurbing creams and such, but never a dye. Any info on how long it lasts? Does it wash out? Is it a hassle? What product do I actually need? Am I just buying this kit and following the steps the page advises or something else? https://www.colourlockaustralia.com.au/colourlock-leather-repair-kit-dye.html
    • These going to fit over the big brakes? I'd be reeeeeeeeaaaall hesitant to believe so.
    • The leather work properly stunned me. Again, I am thankful that the leather was in such good condition. I'm not sure what the indent is at the top of the passenger seat. Like somebody was sitting in it with a golf ball between their shoulders. The wheels are more grey than silver now and missing a lot of gloss.  Here's one with nice silver wheels.
    • It's amazing how well the works on the leather seats. Looks mint. Looking forward to see how you go with the wheels. They do suit the car! Gutter rash is easy to fix, but I'm curious about getting the colour done.
