15.5k for 270rwkw 32 V Spec.with RWC.
Mods are the following;
R34 N1 turbos + dump pipe with HKS actuators.
Power FC.
Nismo Front pipe,
3" Hi flow cat.
3" Cat delete pipe
Apexi N1 cat back.
Apexi RSM.
Apexi pod filters.
Pair of Recaro SR3 seats.
Tein Coilovers.
Whteline Swaybar (F + R)
Adjustable cam gears.
HKS EBC (EVC4 i think).
Apexi Pen turbo timer.
Nismo Gearknob.
17x9 +19 SSR Evolution Wheels.
Have standard exhaust, suspension, airbox.
Sounds good man!
The standard air box you have... Do you have the whole setup including the cold air intake?
The part that slides into the part under the head light?
If you are interested in selling it, I will want it as I am going to use it for a modified CAI.
Sounds good man!
Yes I do have the whole she-bang, not interested in selling it at this stage.
jetta is good my parents have one, drives nice what about accord eurO?
That's another thought, but IMO the ones around my price range are beggining to look a little dated, as compared with the current model. With the Jetta, even a 06-07 is still the same shape as the current model. Plus that chrome grill looks sexy :D
More inspiration:
18x9.5 +24
18z11 +20
Half of boot is fillwd with dynmat, need to remove them along with wires for stereo...
FCC3 Handcontroller doesn't work with RB26 based Power FC, need to buy FCC NT or something? Need to look few pages back or just PM Paul.
so just dont modify it more till you can aford it douchebag
lolz
its like when people say "need to sell car to invest in property" or whatever.
if you cant afford to keep your car you shouldnt even be looking at moving out or buying property coz chances are you wont be able to afford that anyway.
  • Like 1
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
