same as the pods and skirts. pending if i keep the taxi or not
http://www.youtube.com/watch?v=kYmaEHmq2Mg
guy looks familiar
I'll bet that guy didn't put his red uniform on that day thinking that he was gonna become the next interwebz sensation.
i bet there is heapssss more to that kfc story even the article says that other customers have provided info that the people recording had been giving him shit basically.
i worked at maccas i understand how you could rage like that i mean, think of how many mohsens are in the world.
yeh the habibs say it was because they were giving a halal store shit for not serving bacon and the guy lost it when they decided to film them. i wouldnt like being filmed or threatened, then again. thats why i have a steel bollard under my desk at work
shan- remus you say, ill have a look into it
dad wants the 4.4l 8 in his BM to really sing, who makes decent euro exhausts around here?
Eisenmann, Dinan, Remus, AC Schnitzer
expect to pay a pretty penny though..
just tell your dad to go to Glenroy exhausts in campbellfield and get the mufflers removed. done.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
