Dezz - as Justin posted, 5kms... You might as well just get ADSL
It'll be about the same speed and most likely cheaper. But it's a fine line.
Also do not go off "Line of Sight" to the exhange.
Im only about 400m from it, but in effect i am actually about 800m cause the cabling goes around the fken block or something stupid before it comes back up the street to my complex.
And ye, TPG are the bottom of the barrell IMO.
isnt it more like 40BILLION?
When was the last time you saw Labour deliver something on time & less than 20% over budget?
It'll be well into the 50mil at the very least if they are touting 40mil at this stage. Guess who's going to pay for that difference?
End of the day a NBN is fken pointless as we are still externally limited.
People will be under the impression it will bring faster internet, faster web page loads, faster downloads etc. Fact is - it won't.
We are still limited by the residential connections to the rest of the world.
EG:
Residential/Commercial "ping" to the US is around 180-200ms
Industry (Oil & Mining companies/big commerce etc) using the super uber sea pipeline is around 70ms
Its over a 100% increase to the average peasant just because of the external links. Nothing to do with the network in AUS.
By putting in a NBN, the pings/latency will NOT drop for residential people simply because they are not upgrading the O/S & External connections.
The money would be better spent on investing in wireless within AUS, and then upgrading the underwater connections for residential/commercial use to similar grade that big business has now.
THAT would be a far better way to spend the money and it would actually show tangible benefits.
Hell even forget the wireless all together and just do the external connections.
Also Telstra's current nutsack strangle hold on everything is fked too.
Just to get out of the US via IINET, it takes i think 10 or 11 "hops" across various points to hit the US. Each point adds delay/latency etc.
Where as if you are with Telstra the equivalent is about 6 hops IIRC which speeds the net up and gains you can actually feel/notice.
Simply put Labour/Conroy etc, all have no fking clue. It's such a gross waste of money and really jacks me off.
We are going to pay MORE than we should, get ripped off and end up getting something that in 10yrs time will be old-hat tech.
EG:
yeh i though tthe NBN was costing 40 billion not millions.
i dont know the full background on why new estates dont get everything but it may even depend on the builder of the estate too
in keilor all the cables are underground (no power poles etc) which is great and it just happened to have bigpond cable
so i was lucky and couldnt be bothrered with a phone line so went cable
In the old days, they would build huge ass buildings for the exchanges because they thought the tech needed the space. Not until around 1990 they realised it doesn't need as much space, just as big as a house. So the reason why old places get everything, because they have the room. New exchanges, they just build a little house for it. and even sometimes just use a trailer. Old exchanges = cable + adsl2+.
New ones, they only have room for the telstra one. if they have more room. other providers will fight for it, plan out the layout. and chuck it in.
I wish i lived in keilor downs where there was cable and multiprovider 2+. But taylors lakes is running on a sub exchange which is apart of a big exchange consisting of taylors lakes, sydenham and hillside. >.>
+1 rocker cover gasket...
the oil lower has probably just leaked down the outside....
hit it with degrease and see where it re-appears
hmm could be a leak behind where its coming down from. Dont see any obvious leaks around the rocker cover gasket. Had that shit replaced like 2 times already. Keep blowing these gaskets (if its the case again)
Will give it a proper look over in the day tomorrow.
time for beers
i'd prefer to sell it whole... if i can get the price, then i'll happily let it go...
i've put too much work into it to part it out.... but i will if i have to :/
How much you selling it for again?
Pretty much it all has stopped for the time being until everyone knows whats going on.
True that. I sell fibre optic cable and the amount of calls relating to the NBN I get without having any idea what's going on is unbelieveable.
lol and you think rb25 is gutsy off boost?
would be better than a 20
julliete, have you tried a $1 reserve auction on ebay for your car?
im having ALOT of interest, half of which is low ball offers but some are genuine
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
