weren't you after some grandpa spec VW/Euro? lol
are Evo 5 and 6 same looks wise?
Haha, yeah I was, but fwd I was a bit meh about.
5 & 6 are pretty similar, but the 5 has orange corner indicators and few other differences. This one has a 6 TME front bar too
anyone wanna come fishing tomorrow morning meet alvin and i out the front of audi in the city at 4:30 sharrrrpppp
if yall want my number its in my sale listing
and i unclipped the mechanical chin lip cables so im rockin it 24/7 lol
already scraped it while coming out of a carwash
Edited by Mohsen
i fkn NEED to hit up nam
haha deffinatly well worth it
much much better than expected :D
so cheap too
why surprised? The fatcats moving production to Vietnam from Europe/America/Australia need to get around from their hotels :P
haha probably :P
but still its more expensive to buy acar there than over here
they are charged 200% on top of the purchase price :S
Singapore has heaps of nice cars here too
seen soo many m6's
Put a deposit down on an Evo 5!
nice which one?
fair enough
good choice, if you're not too fussed over interiors...
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
