ah sucks :(
noticed a fair amount of shit drivers lately
theres been a stack of accidents this week, i seen 3 cyclists get knocked off in St Kilda yesterday. was kind of funny they just lay on the ground and wouldnt move like they were playing dead, blocking of most of Beac parade in the process.
Damn pushbike riding drama queens Pretty sure there was nothing wrong with any of them, there was no blood or anything even the guy that hit them appeared to be laughing a little as he called for help..
Probably had their shoes still stuck in the pedal bolsters and couldn't get out!
Kind of like any AFL umpire that gets bumped and falls over like he's been shot in the brain...
Particularity the one from the weekend just passed, can't remember what game it was but after the center bounce he copped a slight knock from behind and went down like a dead man, stayed there for 5 or so seconds and then got up and appeared seriously shaken....
Unlucky for him they zoomed in on him when he was on the ground and he looked fine, looking around like a hurt child waiting for attention..
If anyone finds the video of that or similar incidents, please do post them up.
haha, nah, i think they just wanna make the scene more dramatic than it needed to be, possibly there way of protesting for cyclists rights or something..
cyclists don't have right's... they should all be run over as a matter of course
Go to YouTube...type in "soccer".
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
