ah sucks :(
noticed a fair amount of shit drivers lately
theres been a stack of accidents this week, i seen 3 cyclists get knocked off in St Kilda yesterday. was kind of funny they just lay on the ground and wouldnt move like they were playing dead, blocking of most of Beac parade in the process.
Damn pushbike riding drama queens Pretty sure there was nothing wrong with any of them, there was no blood or anything even the guy that hit them appeared to be laughing a little as he called for help..
Probably had their shoes still stuck in the pedal bolsters and couldn't get out!
Kind of like any AFL umpire that gets bumped and falls over like he's been shot in the brain...
Particularity the one from the weekend just passed, can't remember what game it was but after the center bounce he copped a slight knock from behind and went down like a dead man, stayed there for 5 or so seconds and then got up and appeared seriously shaken....
Unlucky for him they zoomed in on him when he was on the ground and he looked fine, looking around like a hurt child waiting for attention..
If anyone finds the video of that or similar incidents, please do post them up.
haha, nah, i think they just wanna make the scene more dramatic than it needed to be, possibly there way of protesting for cyclists rights or something..
cyclists don't have right's... they should all be run over as a matter of course
Go to YouTube...type in "soccer".
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
