Zuck me Alex. Blitz return flow ftw...all return flows need some reo choppy. Blitz is atleast a quality item and looks good when done.
fb is legendary for finding awesome ppl i lost touch with like 7, 10 and 13 yrs ago.. no contact details til now.. too hard to keep in touch when you move interstate and all that shit
If they were so awesome, why did you lose contact with them in the first place? People move on, it's normal. Sustaining contact with people you don't plan on seeing in real life is pointless IMO. And so Facebook destroys the need to see people in real life if they can perform social responsibilities from the comfort of their bedroom. As it has done to so many people...
because I moved to Melbourne? Back when few ppl had a mobile phone and/or email? Would you like my life story? How exactly did this become an opportunity to give me shit? Actually I have SEEN and fully intend to see the rest of those ppl I haven't seen in years when I next go to Sydney or they come here. Those friendships are strong enough that I can *not* see ppl for 10 yrs but can see them tomorrow like no time has passed at all.
And they had no house phone or mailing address? Reality is, if you really want to stay in contact with people, you will without the help of Facebook's past digging services. People did it long before Facebook came along.
im justgunna chuck this out there, i dont expect alot of support.
But am i the only one who thinks blags car looked better with the old wheels. i mean the enkeis are awesome but the car looks fat and bloated with them, whereas it looked more sporty before
so whos with me?
I got bored of xd9s, became to common for me... The enkei's aren't too much bigger that what the xd9s were.
Sporty enough?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
