f**kk i was just near nandos in doncaster and after seeing that it makes me want to go back there :(
also anyone have experience with ARK boost controller >,< ?
Edited by bluejeans
Buy my Turbosmart e-boost street for $300! Check out some of the reviews / rrp and you'll be impressed me thinks. Used it in my car for 2 months.
Call ark design and ask them what you need to know?
$5 worth of chicken (if that) and $1 worth of chips. Cost $15 lol
$2 worth of bottled water. Plus cooking it for me. Plus cleaning up after me. Plus making it taste that effin good.
If you can produce the same for $14 I'll come to you instead :thumbsup:
Don't be a peri hater :)
They were fresh out the frier...you can't see temperature in a photo lol. Come get Nandas with me sometime, Boronia have the best chips of any Nandos I've been to!
umad dezz?
I buried my head in my bed to prevent myself throwing a controller through a Samsung LED, so yes.
Think the lack of shine makes them look cold
Maybe...well, they were hot nonetheless. Nandos is never busy enough that they have chips just sitting there like Maccas. iPhone no flash so no shine :/
NFS Underground made me want to rage like that when I'd be winning a race and POW white van out of nowhere takes you out. Many FML moments with that game.
will do, sometime next week, i'll drop you a txt.
do they entertain extra peri peri powder on the fries?
Yer you can ask for it...I'm not a fan though. It tastes alright but the chips on their own are perfect as is.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
