I was good with + - / and * when I was young...used to be able to compute that shit in my head rain man style...knew all the times tables off by heart etc...but then Cos Sin & Tan came along and f**ked things up for me. lol sounds like a group of Asians and wogs.
I was getting A's in maths until music and girls came along. I'd probably be a doctor or something if it wasn't for those distractions lol
Ash, the youngest girls I speak to at the moment are 17.. and weren't you dating a 17 year old just a few years ago? ;) As if you can talk lol
haha first post in the wasteland today and I've already got a bite :D
I had relations with a 17yo that didn't tell me she was 17, and was promptly given the flick after i found out.
Doing it by knowing choice is just a bit different :P
Burnt by Jizzy?
f**k that'd hurt.
hows that working out for you? I'd rekn a young rich doctor would be getting ample amounts of lady attention of a higher quality.
and as for you equation ya'll sooo dumb i just goggled that shit :rofl:
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
