Kids...
Back in my day we used a 9 pin serial port for some 1 on 1 C&C: Red Alert.
And if we weren't in the same room...it was 14.4k baby. We had BAUD rates too bitches.
^ this man knows where its at. Don't forget Duke Nukem 3d and GTA 1 multiplayer
I think I'd rather be surrounded by girls lol. Although our little game of COD was quite enjoyable the other night. I can imagine it being pretty fun while drunk. Couldn't play games for 10 hours though.. 2 hours max for me.
Nar...fark being around girls all the time. Yeah they can be good eye candy and it's cool to chat up / dance with them, or even have sex with them occasionally, but there's only so much I can take of the female company. Male mates are much better entertainment IMO...better laughs...better conversations...better at games...better at drinking. Jerk off before you decide what to do for the night...you'll choose Playstation :)
Games and guys and beer = awesomeness
Chicks and talking chick stuff really gets to ya over time. I do not want to hear anything about another frikin hand bag or a pair of shoes or make up or how her friend was being a total betch and how I shouldn't spend so much time playing xbox.
:spank:
you sound like a fkn 16 year old horny little kid who comes in here and brags everytime a girl walks with 8kms of you. it was like a broken record 20 pages back and your still going.. its really sad and frankly i dont think anyone hear gives one bit of a fck about you and your knob and its travels.
i have sex everyday... and?
jus sayin.. dont take it all personal either we got sick of grant and his car whingers to.
I added it on the end to annoy you, and it got a reaction. Mission complete.
No one is buying your shit anymore.
Im with alex, you just sound like a sad cunt. Try your stories on some 16 year olds or other dream boats as immature as you are and you might do alright.
To put it simply...
And way to advertise it dickhead
Richard Kranium would so displeased with his nick names used in vain.
If you tap everything that moves that would make either of the following true?
- You are Bi
- You have an STD
- You father many children
- You are a male gigglo!
- Your father owns a Viagra manufacturing plant
If you can't answer yes to any of the above then you are full of Sh!t
:nuke:
X2
But seriously Jez-burger, you claim to be trolling everyone with those comments, but you're just embarrassing yourself mate. Nobody cares anymore.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
