i originally took em out for moar lows why do you wanna put em in?
just get a 2nd hand set of coilovers or something..
helper springs compress your coilover springs so they dont fly around when you lift a wheel off the ground haha. People put them in so they can go more low without springs popping out of the seats!
I need to put some in, cause any lower and will pop out.
Paid a pretty penny for my new Bilstein shocks, which are far better than any chinese coilovers. Would be silly to bin them for more lows. Need to just spend more money to convert them to coilovers ~_~
East Bear
A trader used to sell em on here, but only had the beige/tan color which I wasn't a fan of, black was pretty rare...think they were something like $800 a piece back in the day + rails...I had Bride rails on em which aren't cheap either
Thought you'd be keen as mustard for footy training if you're so into running..
It's more the session times I can't deal with, rather than cbfs about training. Work sometimes holds me back late and Tues + Thurs are gym nights for me. Thirds is more about punch ons than footy though!
lol they pop out but they'll go back in place during/after compression. they were a bit noisy after i took em out but it dropped the height another inch or so.
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
