My cheap trasher isn't cheap trasher anymore, bahaha...
Kinda regretted the purchase since so not many people have spare RB20 and gearbox laying around.
Story of my life...
Story of my life...
should of gone for an s13.
i rate r34 gtr's number 1 lol i love the look of them but i also love the r33 gtr's and r32 gtr's they all have something that i like about them. but this is the one car that i have ever owned that i love to drive everyday and puts a smile on my face and thats all that matters.
Story of my life...
lol where did you get the idea that a r32 will be a cheap thrasher? Its not like ive been painting mine 24carot gold over the 5yrs :O
A cheap thrasher would have been a s1 r33 gtst from the westside.
Haters gonna hate. Rollin in my r32 :D
Reason why i got a 33 gtr, i mean id love a 34gtr but another 20k for a LCD screen? lolwat?, sit in a r32 GTR and interior is aids or your girlfriend will adjust the air vent and it will fall off LOL. Front of 34 GTR = sex, rear of 33 GTR = win, if i had teh cash would make mine into a 33.4 or what ever theyre called, can always sell my xenons to help fund the conversion :D
see picture
also, ran the car for a bit
got the first plug out( the cylinder thats down) and no fuel on it. dry as a bone.
so who has a stock rb20 injector for me? lol
f**kin love this guy
u got an RB20 injector?
theyre in my car due to swapping out my Sard's for epa.
Buy yourself a brand new set of sard injectors and nistune. Should set you back $800, but at least they will last you for whatever power you want to push and nistune for future tuning.
Dont bother with GTR injectors, mine leaked after a year. Do it right, do it once. Cut corners on a r32 and it will catch up on you.
Geez who's r32 here doesn't break. Hard to come by these days :D
its an older car, what do you expect?
What I find amusing is that I cant seem to find any s1 burgandy r33's anymore. Couple years back, there were thousands of them. Now they all have disappeared. wtf happened to them
U reckon mohsen has $800 for injectors and a remap? Me no think so
haha, thats only the beginning.
Hopefully they were all written off. f**king can't get a worse combo. 93-94 r33, wine red and auto. I would take a r32 over that haha
haha the black sheep of the r33 family.
haha yeah i drained the wallet pretty well after i got it
im not looking for power gains atm
quick enough for me at the moment, so im just looking to replace the blocked injector and continue driving it
i am buying grants type m bits though :D
edit: i just told my friend(the same guy with dyslexia) that i have a blocked injector
he goes "get a nidl and put it in it"
Edited by Mohsen
Guest
    • There's restrictor pills in the stock boost control hoses. That's how they set the amount that was bled off and hence the "high" boost setting. The usual mod in the day was to remove it and send the "high" boost setting up to about 14 psi.
    • Thanks Duncan, that's the best info I've read. Furthermore after learning about the PCM programming side controlling the factory boost solenoid, the purpose of the solenoid is to "bleed" boost when pin 25 is earthed, thus allowing spring pressure in the wastegate actuator to overcome diaphragm boost pressure, thus closing or reducing the position of the wastegate flap creating more boost as the turbo is able to spin faster. It's pretty cool to see a designated Pill to do exactly this, would have liked to have seen it with a tiny filter over the end for those moments in vacuum.  The constant bleed pill has now been removed completely from the system and solenoid boost control has been restored once again.   Case closed 😂
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
