I'm hoping pump gas cause here we dont have 98RON. Dunno what the knock is gonna be on our horrible gas, might have to go water/meth inj. for a save tune.
Hey Girorostar, yeah most of the fuel you get on the islands is fairly poor ( comparitable to a mix of 91 and cheap ethanol)... I spend quite a lot of time in the carib/lower carib/trinidad etc on private superyachts.
I'd suggest buying 20lt drums of toluene and add a 7:1 mix of gasoline:toluene. Your biggest problem will be that the fuel you get where you are isn't of a constant grade and is usually full of water!
If you tune your car on a 'good' batch of fuel then fill up will a different/poor batch of fuel and drive the car hard you may very well damage the engine quite quickly.
Water will damage your fuel system and will also allow sludge/bactiria to grow in your fuel system (it'll gunk it up pretty quick). The biologicals actually live in the water but feed on hydrocarbons (your fuel) then 'poop' out more water and gas/sulfates etc.
I've helped a few guys with they're imports on the islands, this is what I suggest:
Toluene
Good knock sensor and indicator (eg Power FC)
Good knock correction mapping
Very conservative tune
Single point methanol injection... (seperate tank, pump, injector and controller) Not WMI.
We set up a single point meth injector on a s13 in Sint Maartin... worked quite well!
Good luck
Justin
Toluene
Good luck
Justin
Thanks for the advice Justin, yea the biggest issues a lot of RB motors has on this island is fuel, they dont like it! I will start doing some research on this on how to set it up on my car. Hope everything will go right and i dont blow the engine.
A friend of mine with a r33 gtr made 315rwkw on pump gas here but he has a HKS built motor and another friend of mine with a stock motor r33 gtst made 270rwkw on a very conservative tune cause he had a lot of knock on higher power had to lower the boost. He's still searching for a way to drop down the knock levels, I will tell him about this and see what he thinks.
  • 4 weeks later...
i will try the 5857 AR:82 on my RB26 !!! after i saw the result on a 1JZ from the state .
what do you guys think ?
If you plan to run E85 and 35psi I think you will be VERY happy.
I think you'll find that's about on the money... They're a great turbo if you'r running BIG boost numbers. Don't expect tooo much from 20psi.
Cheers
Justin
  • 1 month later...
  • 1 month later...
so what did the powertune r34 gtr with the 7175 billet on it make powerwise? the powercruise youtube vid is impressive to say the least....
About 0.0197hp/$1 at the fly.
Find the turbos suggested output and do the math, then consider that as a rough minimum.
Your chasing the wrong product, Honda has the power of dreams!
After the last dyno run, I've changed a few things- most importantly the exhaust. Turns out the center muffler has partially collapsed causing higher backpressure in that section of the exhaust. I'm not shure how that will change the power output, however it feels more responsive now.... either way I was allways changing setups to a top mount TD06 and there's no point re-tuning untill I get the new turbo on.
If anyone is interested I have my 5557 for sale at the moment. $1400 with 46mm wastegate and professionally made stock manifold adapter.
http://www.skylinesaustralia.com/forums/topic/361517-billet-turbo-hks-manifold-and-a-heap-more-good-gear/page__gopid__5772382#entry5772382
Cheers
Justin
  • 2 months later...
  • 2 months later...
So..... anyone got anymore results with these turbos?
PJ??? anyone?
also wat was the rear housing size on the precision billet 7175 used on the white r34 gtr
i want to go a 6765 divided for street and the exact 7175 used on the powertune 34 for show, race n dyno
Here's a suitably ridiculous result from an EVO in the states running a new Precision PT6766 (.82a/r hot side) at just over 40psi on E85:
Mustang Dynos read in the territory of Dyno Dynamics, they are not generous dynos at all - to put down 850awhp/634awkw this is a ridiculous piece of machinery. Imagine one on an E85 slurping RB30? :D
im ordering 1 monday...
built tomei 2.8, 288 jun cams, 2000cc id injectors... powertune twin 044 in tank setup...
wil b interesting, hope to have running by xmas or just afta...
do u think ported "hp" cover would make much difference over the non ported "h" cover?
cheers
cheers
On a big capacity good spooling engine you'll need the ported front cover to avoid surge but Rb's are known to spool slowly so you should ok without it...
bigmikespec, just want some advice from an expert.. wat are the pros n con of having and not having the surge cover for "my" application on this turbo?
i want to run about 25-30 psi on the street on e85 and keep winding it up for race til it tapers off the power/boost curve...
cheers
    • The average previous owner for these cars were basically S-chassis owners in the US. Teenagers or teenager-adjacent. I often tell people that neglect is easier to fix than something that was actively "repaired" by previous owners.
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
