I'm hoping pump gas cause here we dont have 98RON. Dunno what the knock is gonna be on our horrible gas, might have to go water/meth inj. for a save tune.
Hey Girorostar, yeah most of the fuel you get on the islands is fairly poor ( comparitable to a mix of 91 and cheap ethanol)... I spend quite a lot of time in the carib/lower carib/trinidad etc on private superyachts.
I'd suggest buying 20lt drums of toluene and add a 7:1 mix of gasoline:toluene. Your biggest problem will be that the fuel you get where you are isn't of a constant grade and is usually full of water!
If you tune your car on a 'good' batch of fuel then fill up will a different/poor batch of fuel and drive the car hard you may very well damage the engine quite quickly.
Water will damage your fuel system and will also allow sludge/bactiria to grow in your fuel system (it'll gunk it up pretty quick). The biologicals actually live in the water but feed on hydrocarbons (your fuel) then 'poop' out more water and gas/sulfates etc.
I've helped a few guys with they're imports on the islands, this is what I suggest:
Toluene
Good knock sensor and indicator (eg Power FC)
Good knock correction mapping
Very conservative tune
Single point methanol injection... (seperate tank, pump, injector and controller) Not WMI.
We set up a single point meth injector on a s13 in Sint Maartin... worked quite well!
Good luck
Justin
Toluene
Good luck
Justin
Thanks for the advice Justin, yea the biggest issues a lot of RB motors has on this island is fuel, they dont like it! I will start doing some research on this on how to set it up on my car. Hope everything will go right and i dont blow the engine.
A friend of mine with a r33 gtr made 315rwkw on pump gas here but he has a HKS built motor and another friend of mine with a stock motor r33 gtst made 270rwkw on a very conservative tune cause he had a lot of knock on higher power had to lower the boost. He's still searching for a way to drop down the knock levels, I will tell him about this and see what he thinks.
  • 4 weeks later...
i will try the 5857 AR:82 on my RB26 !!! after i saw the result on a 1JZ from the state .
what do you guys think ?
If you plan to run E85 and 35psi I think you will be VERY happy.
I think you'll find that's about on the money... They're a great turbo if you'r running BIG boost numbers. Don't expect tooo much from 20psi.
Cheers
Justin
  • 1 month later...
  • 1 month later...
so what did the powertune r34 gtr with the 7175 billet on it make powerwise? the powercruise youtube vid is impressive to say the least....
About 0.0197hp/$1 at the fly.
Find the turbos suggested output and do the math, then consider that as a rough minimum.
Your chasing the wrong product, Honda has the power of dreams!
After the last dyno run, I've changed a few things- most importantly the exhaust. Turns out the center muffler has partially collapsed causing higher backpressure in that section of the exhaust. I'm not shure how that will change the power output, however it feels more responsive now.... either way I was allways changing setups to a top mount TD06 and there's no point re-tuning untill I get the new turbo on.
If anyone is interested I have my 5557 for sale at the moment. $1400 with 46mm wastegate and professionally made stock manifold adapter.
http://www.skylinesaustralia.com/forums/topic/361517-billet-turbo-hks-manifold-and-a-heap-more-good-gear/page__gopid__5772382#entry5772382
Cheers
Justin
  • 2 months later...
  • 2 months later...
So..... anyone got anymore results with these turbos?
PJ??? anyone?
also wat was the rear housing size on the precision billet 7175 used on the white r34 gtr
i want to go a 6765 divided for street and the exact 7175 used on the powertune 34 for show, race n dyno
Here's a suitably ridiculous result from an EVO in the states running a new Precision PT6766 (.82a/r hot side) at just over 40psi on E85:
Mustang Dynos read in the territory of Dyno Dynamics, they are not generous dynos at all - to put down 850awhp/634awkw this is a ridiculous piece of machinery. Imagine one on an E85 slurping RB30? :D
im ordering 1 monday...
built tomei 2.8, 288 jun cams, 2000cc id injectors... powertune twin 044 in tank setup...
wil b interesting, hope to have running by xmas or just afta...
do u think ported "hp" cover would make much difference over the non ported "h" cover?
cheers
cheers
On a big capacity good spooling engine you'll need the ported front cover to avoid surge but Rb's are known to spool slowly so you should ok without it...
bigmikespec, just want some advice from an expert.. wat are the pros n con of having and not having the surge cover for "my" application on this turbo?
i want to run about 25-30 psi on the street on e85 and keep winding it up for race til it tapers off the power/boost curve...
cheers
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
    • Yeah Jap import. Fairlady Z then! I'm a bit the same.  They've been on my radar for a fair while but then just impulsively decided to buy one!  Was going to just buy an NA and add turbos to it later but decided to save the f'ing around and just buy the turbo version.
