I'm hoping pump gas cause here we dont have 98RON. Dunno what the knock is gonna be on our horrible gas, might have to go water/meth inj. for a save tune.
Hey Girorostar, yeah most of the fuel you get on the islands is fairly poor ( comparitable to a mix of 91 and cheap ethanol)... I spend quite a lot of time in the carib/lower carib/trinidad etc on private superyachts.
I'd suggest buying 20lt drums of toluene and add a 7:1 mix of gasoline:toluene. Your biggest problem will be that the fuel you get where you are isn't of a constant grade and is usually full of water!
If you tune your car on a 'good' batch of fuel then fill up will a different/poor batch of fuel and drive the car hard you may very well damage the engine quite quickly.
Water will damage your fuel system and will also allow sludge/bactiria to grow in your fuel system (it'll gunk it up pretty quick). The biologicals actually live in the water but feed on hydrocarbons (your fuel) then 'poop' out more water and gas/sulfates etc.
I've helped a few guys with they're imports on the islands, this is what I suggest:
Toluene
Good knock sensor and indicator (eg Power FC)
Good knock correction mapping
Very conservative tune
Single point methanol injection... (seperate tank, pump, injector and controller) Not WMI.
We set up a single point meth injector on a s13 in Sint Maartin... worked quite well!
Good luck
Justin
Toluene
Good luck
Justin
Thanks for the advice Justin, yea the biggest issues a lot of RB motors has on this island is fuel, they dont like it! I will start doing some research on this on how to set it up on my car. Hope everything will go right and i dont blow the engine.
A friend of mine with a r33 gtr made 315rwkw on pump gas here but he has a HKS built motor and another friend of mine with a stock motor r33 gtst made 270rwkw on a very conservative tune cause he had a lot of knock on higher power had to lower the boost. He's still searching for a way to drop down the knock levels, I will tell him about this and see what he thinks.
  • 4 weeks later...
i will try the 5857 AR:82 on my RB26 !!! after i saw the result on a 1JZ from the state .
what do you guys think ?
If you plan to run E85 and 35psi I think you will be VERY happy.
I think you'll find that's about on the money... They're a great turbo if you'r running BIG boost numbers. Don't expect tooo much from 20psi.
Cheers
Justin
  • 1 month later...
  • 1 month later...
so what did the powertune r34 gtr with the 7175 billet on it make powerwise? the powercruise youtube vid is impressive to say the least....
About 0.0197hp/$1 at the fly.
Find the turbos suggested output and do the math, then consider that as a rough minimum.
Your chasing the wrong product, Honda has the power of dreams!
After the last dyno run, I've changed a few things- most importantly the exhaust. Turns out the center muffler has partially collapsed causing higher backpressure in that section of the exhaust. I'm not shure how that will change the power output, however it feels more responsive now.... either way I was allways changing setups to a top mount TD06 and there's no point re-tuning untill I get the new turbo on.
If anyone is interested I have my 5557 for sale at the moment. $1400 with 46mm wastegate and professionally made stock manifold adapter.
http://www.skylinesaustralia.com/forums/topic/361517-billet-turbo-hks-manifold-and-a-heap-more-good-gear/page__gopid__5772382#entry5772382
Cheers
Justin
  • 2 months later...
  • 2 months later...
So..... anyone got anymore results with these turbos?
PJ??? anyone?
also wat was the rear housing size on the precision billet 7175 used on the white r34 gtr
i want to go a 6765 divided for street and the exact 7175 used on the powertune 34 for show, race n dyno
Here's a suitably ridiculous result from an EVO in the states running a new Precision PT6766 (.82a/r hot side) at just over 40psi on E85:
Mustang Dynos read in the territory of Dyno Dynamics, they are not generous dynos at all - to put down 850awhp/634awkw this is a ridiculous piece of machinery. Imagine one on an E85 slurping RB30? :D
im ordering 1 monday...
built tomei 2.8, 288 jun cams, 2000cc id injectors... powertune twin 044 in tank setup...
wil b interesting, hope to have running by xmas or just afta...
do u think ported "hp" cover would make much difference over the non ported "h" cover?
cheers
cheers
On a big capacity good spooling engine you'll need the ported front cover to avoid surge but Rb's are known to spool slowly so you should ok without it...
bigmikespec, just want some advice from an expert.. wat are the pros n con of having and not having the surge cover for "my" application on this turbo?
i want to run about 25-30 psi on the street on e85 and keep winding it up for race til it tapers off the power/boost curve...
cheers
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to it's full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so damn hot in there, that made it all the more easy to remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. I was standing there looking at the car and said 'f**k it'. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
