Mate if I was you I would have done it a year ago, I hate my -5s I should have went single from the start. But than I also like not having to worrie about the cops.
What exhuast you gunna run? Or you going to adapt the RPM one?
There is an issue SOMEWHERE in your setup. 330 on 5's is a little below par.
Well the RP one is twin 3 inch all the way. I'm thinking about not running the twin's front pipes, coming out the back of the turbo in a 4 inch then splitting that into a twin 3 inch to meet up with the "catback". Each gate will pluimb into 1 of the 3 inch pipes.
The SR result im reffering two, we overlayed my 2.8 and 5's. This SR with a 6262 had MORE bottom end grunt and made an extra 10 kw up top.
i no man, ill work it out one day, got a new exhuast coming and a new intake setup. So ill try that out, and c how it goes. If nothing improves ill just drive it as it is, till Stevo comes up with the goods on the bits and peaces to make her a lil bigger on the bottom end if you no what i mean, than prob throw the -5s in the bin lol
im very interested to c how this turns out but
Precision turbos are getting a lot of love recently, but with the results they are putting I think it's definently justified.
Is there a reason they aren't as common as Garrett's? Like we're they not to good back in the day or something along those lines?
^ Good question. I've followed US/Euro results for years and bleated on about some of the results people had been getting wth FP and Precision turbos for years and said the Garrett GTX turbos have been too little too late but for a large part seems to have fallen on deaf ears MOSTLY here, got the typical "inflated dyno figures" speels. Understandable that people need to see the results from familiar environments and setups, but that is probably largely why they haven't spread around this part of the world so much. Overseas in the EVO/Supra world they are EVERYWHERE.
Its also alot to do with the parity of the dollar, i have bought a one, yrs ago, and sold it and i bought a innovate turbo yrs ago from the U.S
when they where the "big" thing, but they where crazy money compared to garrets once you changed the dollar over and imported
compared to a garret here.
The other part is people talked out of there absolute arse about them on here without even trying them..with all the inflated dyno and need mega
high boost to work bullshit..its given me a good laugh lately.with the all results coming forth ...lol
cheers
darren
A little? lol... A LOT!
Be interesting to see what you think, going to have the -5s running first for a month and then do back to backs?
Given you are changing head etc ;)
I'm still undecided Ash. It's a lot of work and a lot of dicking around.
Part of me thinks I've gone too big but if a SR is matching my -5 effort then I think I can go up one size, given I have 500 cc over that particular result. If it is too big well I'll drop back to 6262 or 6266.
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
