Tuned up the sr20 yesterday ready for the drags.
21psi pulled 328kw
30psi pulled 385kw
5558 .6 44mm external gate, poncams and forged motor
Theres is more in it but ringing the poor little things neck.
Unfortunately drags got cancelled due to the weather so thats for another day.
21psi pulled 328kw
30psi pulled 385kw
Thats a lot of power for a 2L on 21psi, is that on E85 though? Hey Mick O hurry up already with the nats, I cant wait to slap my one on lol..
Yes ethanol. No way would i push 30psi with 98 pootrol
Finally got some numbers but its not done yet,
On the New motor, with the 6262 .84 TS BB CEA.
Run-in tune (super safe) verylow/negative timing, 9-10 psi. 210-220 rwkw.
Turbo is super responsive and perky even with the timing so low, I noticed instantly its very throttle responsive, its very possible my intake setup helps in this regard. But the way it moves the air so quickly I have a good feeling this setup will be pretty decent on the 30/25 with vct!
One noticable characteristic.. the turbo seems very loud. even on low boost. however i am moving from lowmount to high mount during this build, so that might be why i think that.
will be doing real tuning next week if all continues well. Will post numbers as promised when its done. Unfortunently still running hte PFC and Tomei Z32 as no one has purchased the gear yet.
-dale
results yet?
Big boy turbo, wha happened to wanting response lol
Yeah, things got a bit out of hand with the engine build and from what I have seen so far this turbo should still have good enough response yet make massive power. Its either this or the 6266. Will see how we go.
I have a 6466 on an rb28, and i expect in excess of 500awkw. Might be a little bit too extreme on a daily strees sil. Buut, look at PJ's THING, because thats what it is, a freakish THING. It has a monster and still makes powers that are usuable for speeding up the rotation of the earth arouns the axis of the suns, and stuff
I think it will be OK.
There's a 180sx 2.0 VE non VVL, with a 6466 that made 536rwk@34psi with quite reasonable response.
Then there's James NFI's S15 2.3 VE VVL, with a 6262 that made 430rwk@24psi with ballistic response (but yet to have final tune).
With my motor 2.2 VE VVL I figure the next size above from James should still provide enough response yet be able to make 450-500rwk should we choose to push it that far.
It will be either a 6266 or a 6466.
Hahaha I laughed pretty hard when I read that! Pretty deep!
Allan, the 6466 on your 26 will be fine and will comfortably make the power ;)
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
