And it's on low boost
I'm sure it would crack 300 if the guys at JEM felt okay pushing more boost into it. But again they have their reasons for not doing that.
Waiting on a payment for a set of rims I sold then I should be able to show some water meth results to people interested in what it can do with ping resistance.
  • Like 1
Well the ching ching cooler is doin a good job because the outlet pipe up till a bit past the battery tray is nice n cool, BUT once you reach the rad/fan area it heats up pretty quick all the way to intake mani. So I know its not the cooler thats why I wanted to re-route and heat wrap that bit of top pipe away from rad/fan and cam covers
Mines the same on stagea, hot as f**k on that corner and side piece, then water is injected near the BOV , after that its cooler..
i was making 641nm, so looks like the two turbo's are similar on that boost, not sure about the housing differences though..
its a good result though, looks like 16psi, probably needs atleast 20psi to really unleash
Thats a pretty good point, I realise that I'm making 286rwkw on 16psi not 18psi, as it drops down to 16 up the rev range where the power peak is, so its a good figure, what will happen at 20-22psi I cannot wait, or 26psi if I add water injection.. :) 2nd gear can be pretty scary, even with a moderate stab at 4000rpms it gives a nasty lurch forward and skates sideways / wheelspins about a bit, 3rd gear same story but to a lesser extent, am running good compound tyres 18" Potenzas at the rears.. lurving it man... My dynocurve shows that it shoots up 100rwkw in about 400-500 rpms (from 100 to 200rwkw), this the bit thats fun... :yes:
try this, find a nice smooth piece of tarmac, let second gear come up to 4000rpm without boost, then drop the hammer and fry them for 60meters ,
awesome feeling, lol oh and PRIVATE ROAD obviously :)
Edited by AngryRBGTX
hahahah..now that you told me, I will definitely try that out. Why are you only running 16psi on E85 (your signature), go 26psi.. Hey you the same guy as sliver33 something right?
yeah i changed my name, well the usual advice is 300kw is the limit for stock bottem end so with that in mind 320kw is a good number and looking very safe on E85, i like to stay cautious rather than see how long the piece of string is... lol.
You should go E85 next, cost me around a grand extra.
yeah i changed my name, well the usual advice is 300kw is the limit for stock bottem end so with that in mind 320kw is a good number and looking very safe on E85, i like to stay cautious rather than see how long the piece of string is... lol. Plus im working on a new project, got a cheap XR6 ute which im thinking bout turbo conversion :)
i have never read my name so much on a forum before.
update jez has already told most of it but i will do it again anyway.
setup so far has put up with a drag session, private track day , 2 SAU cruises ,my wedding and a bunch of other driving.
i have been watching temps and oil use like a hawk, engine still seems very very healthy, min amount of breathing and so on.
and yes my old BOV which we installed before wakie was a massive leak no wonder it felt not as fast.
all leaks are now fixed and skybitch is better then ever thanks to jez.
below is the print out
Its very interesting to see the numbers being made with a 0.63 rear housing on the 5558, ill have to look into this more before ordering one, but is there anyone running a 0.82 rear?
I'm over the moon with how much power the baby turbo put out the best part is it made the exact power I wanted
Going off of the road speed between kurtis and jez's graphs there doesnt seem to be that much difference between when they are on full boost.
I remeber reading somewhere that Kurtis' setuo was all in by like 3750rpm but cant recall what rpm jez was hitting full boost.
If the difference is negligible, youd almost go the ts .84 6262 just for the extra power it gives
Hey Kurtis, with that much power you could put down a high 10s quarter mile? Not sure why you got a 13.098, guess tyres/suspension/launch was the problem. I have yet to learn how to launch..
Anyone done any back to back (or similar) on the 6262 and 6266? Will be deciding between these in 0.84 TS for a 2.2 VE SR. Leaning towards the 6262 atm.
i have seen dyno sheets floating around which are probably in this post somewhere anyway - which show the difference in the response between, 6266, 6466,6766 being about 500rpm on a 3.4L ...
I have even emailed precision directly who have confirmed that it would be about 300-500rpm on a 3L
If you looking for a 3076R equivalent then go the 0.63/ 5558 which is what I did from research and Unigroup's advice, if you looking for bigger, then consider the 6XXX series...
I can explain my time , first time drag racing ever.
Still had suspension setup for corners .
So basically driver error but hopefully with practice I will put a time to match speed but aiming for higher speed as well.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
