^ that was cool, but what was more impressive about the turbo is that it was hitting 20psi by around 4200rpm, and also that they did a GTR a couple of weeks earlier that made 605awkw with a PT6466! Very very cool turbo.
Yep it's an animal. Very very nice curve, very responsive and damn is it quick!! Still had a lot more in it as they weren't leaning on it at all but at that power there was no need to.
Ninos's engine is a litre smaller than mine and makes peak torque 500rpm earlier and goes on to make more power with a bigger power band. Granted he is pushing some boost into it but it does prove that combo is killer.
Ahh that's good to know Nino's still had more in it, I found it strange it fell short of the GTR (and others) that have run that turbo. Still a scary amount of power, I've been in Silvias with half that and they've been pretty damn rapid!
So any of these dyno plots likely to be available to nosy at?
I tuned a VL Fully built RB30 single cam (Aftermarket cam) on the weekend with this model - Precision 71mm Billet Turbo 7175 rated at 985hp........price $1,439.99 USD
It was making 25 psi by 4,000 rpm in 3rd and 4th gears. It was an animal, barely any lag at all which surprised me.
I have Ninos' graph and video. Will post up at some point when I get a chance.
I was excited by his result as my engine is almost identical bar slightly smaller cams and some strengthening mods that he has (that are not power adders as such)
Only concern with the 6466 is the reliability. Power and response is sensational but have some real concerns with reliability of Precisions.
I thought you were running a DET, not a VET?
    • They are, a good friend of mine bought one to replace his blow factory turbo, running a Toshi Tune reflash. Just use their supplied water/oil lines and you're good to go. At the time, they were like $900 delivered.
    • This is an option for 100% bolt on, the GCG high flow -  https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html Also, I'm pretty sure hypergear does a high flow that is 100% bolt on, it just doesn't make as much power as their bigger high flows.  Even if you get a hypergear turbo that requires you to chance the intake piping, it is a really simple modification. It can be as simple as a piece of silicon hose and you pop a filter on the end. It doesn't have to be some crazy pie cut titanium work of art intake pipe.  If you have the ability to swap the turbo yourself, you would be able to sort the intake piping out.
    • Just as a thought, if it's in neutral, thats your drive line disconnect, not the clutch. Clutch slip at the dyno with pedal fully out, is actually adding a second disconnect. So it's not a clutch issue if you're in neutral. Just a bit of friction dragging the output around while in the air.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
