1 hour ago, burn4005 said:
its interesting that the Precisions seem to be happy well past the flow the manufacturer rates the compressor for. whereas Borg Warner made their turbines strong enough to cope with the choke speed of the compressor they paired it with and not much more as its outside the design parameters.
They just quote some arbitrary hp number which annoys me no end, if you run a "705hp" Precision turbo on a diesel engine you are not going to make anywhere NEAR that power - though if you remove that turbo and then put it on a serious engine running "FTW Black" race fuel you could end up making 900-1000hp - yet on both engines it could have been completely at choke flow.
Even "lb/min" really is a slightly crap rating for air flow, the whole "corrected gas flow" thing is all well and good when Borg Warner, Garrett, Holset etc all use different standards for defining what mass air flow is moved in whatever conditions.
Just looking for a bit of guidance,
I have a built rb26 forged bottom end stock piston size nur block.
Head is very ported 1mm over size valves
276 degree cam shafts billet
Vct custom cam set up off a rb25
hypertune plenum
6 boost manifold 6266 gen2 pricision turbo,.Large enough fuel system to run e85
Just looking for where i would be at power wise i don t really want to run 40 psi or any thing as its a street car, I had around 480 awhp with my hks 25/30 twin turbo setup on a stock motor that threw a ring lan at powercruise a few years ago. I liked the response alot used to chop alot more powerfull cars due to response and grip.
Any one done this combo and have graphs or any idea where abouts id be at.
Boost is nearly irrelevant. Its timing and tuning. How much is blown out the exhaust @what deg. Of timing, manifold backpressures ect ect. You could theoretically run 100psi safely if the cam,crank,ignition and injection timing was to suit. Dont be afraid to run boost with these turbos. Ive found the couple ive had anything to do with like to be in the mid to high 30s or even 40s.
17 hours ago, Gtir-keiron said:
rb26 forged bottom end stock piston size.
6 boost manifold 6266 gen2 pricision turbo,. e85
Turbine housing will be the deciding factor on your power figure, and response.  Eg. single scroll 0.84 will be way different from split pulse 1.15.
If you're limiting yourself to 2 bar, could range from 450 - 550kW.  Your rpm ceiling will also play a part in that figure. So there's a few variables.
The first and most obvious difference is complexity and cost.  Packaging/engineering difficulties being part of that situation.
The second and less easy to quantify with a dyno sheet is throttle feel and how it drives into boost or how it behaves on gear changes etc (different from how it runs at WOT).
Otherwise, the power figure will (should) be higher with a bigger housing simply because the engine can exhale more efficiently, lower backpressure, better scavenging, less retained heat etc etc.
There are reasons to go with either approach, and quite a few traps that can prevent "best" outcome for each.
I'm currently engineering a 6266 0.8 single scroll 6boost setup onto a basic 30DET engine.  Knowing that engine performance is only a part of what makes the car go fast.
  • Like 2
Its .84
split pulse manifold
  • 3 weeks later...
can anyone tell me where the best deals are being done on a 6466 nowadays?
I am wanting to try a 6466 on our engine and see if it makes more power than the 6766 we currently have fitted to it.
Would a 6466 with a .8 rear make over 500rwkw? The 6766 is a 1.0 rear, T4 split pulse on a genuine GReddy exhaust manifold.
The car is tuned by Unirgroup and is currently making 460/480rwkw at 30psi. Runs 138mph consistently
Wouldn't it be healthier to run the 6466 with the current 1.00 rear? It's such a large snail, don't stick a cork up its ass and run the peanut 0.84. In AND out!
Why is it "only" making 480 on 30 psi? Sounds kinda low given boost and turbo size. Possible issues/restrictions in the setup?
  • Like 1
curiosity more than anything mate. i am sure the ass end of both turbo's would be interchangeable so if the 6466 struggled too badly with a .8 ass we could throw the 1.0 on and do some more testing.
As you can see in this post there are cars making more power with a smaller turbo though i am led to believe the 6766 isnt best suited to an RB which may be our issue. It flows a bit more air but doesnt like the rpm side of things.
  • 4 weeks later...
On 8/9/2017 at 7:12 AM, SRS13 said:
I haven't posted the results of my 6466 on a SR22VET.
On the JEM dyno, it made 512rwk on 34psi with 34psi on board at 4300rpm (from memory).
Haven't run it at the creek yet.
Got a Dyno grpah?
Anyone used the PTE 6062 Gen 2 yet? I'm currently converting from Sr20det to Vet and seems to fit the bill nicely between the 58 and 62 series range, (Currently making 410rwkw on a 5858)
Kinda surprising the Gen 2 6062 is rated 50hp higher than the Gen 1 6262
  • 2 months later...
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
