31 minutes ago, ido09s said:
How much power does the car make now?
have you raced it yet and what mph did it run?
I was working from his sig: (I'm used to Dynapacks and the mph vs power figure don't add up so there may be more to the story)
Was 10.61 @ 127.9 mph in 2011 (old tune on 523kw forged 2.6). 2018 power with 2.8 coming soon
I don't see the 6466 getting even close to 500kw on 98 octane.  My 8.9:1 cr RB34 with the 6466 managed 385 kw on 98 octane at gate pressure of 12lb. Tuned on a 30+ degree high humidity day.  Alice springs has much drier air.
Turned up to 18 it was able to make more low and mid range but was knock limited at around 400 ish kw.  E85 solved that but the turbo still runs out of puff and maxed at 525kw.
I don't have any real drag times that count as I've only had one clean pass on low boost, that was also a soft start.  11.6 @ 125mph.
The options are either to have a race fuel tune, low compression/high boost or add a WMI kit.  You have to keep that knock under control, and the only way you'll get past 500kw is to get that cylinder pressure up.
they certainly don't.
Actually the R33 does. A car I built went 330rwkw on Unigroups dyno and ran 11.3@125.
That 10.6 he said it ran @127 must have been a reasonable back off and in that case his current setup probably should run into the 9's anyway so doesn't really need changing. Probably just needs a decent tune and a nice ECU controlled boost controller
so are you saying your car made 525rwkw but only ran 125mph?
3 minutes ago, fatz said:
500kw is more like 145mph?
should be about that yeah. My S14 makes 500rwkw on Unigroups dyno and runs 138mph all day every day.
Low boost, 18lb so I guess around 400kw.  Not the 30lb 500+kw tune.
I only mentioned it in case that was going to be someone's next question.  I suspect with my crappy driving and new tyres I could probably do a low 10.  Also I have a 3 hr return drive to the nearest track, and it wasn't trailered.  I didn't want to risk breaking a diff or something.
The point I was trying to get across is that 98 octane will knock limit you to around 400kw even on a very stout engine build.
Edited by GTRNUR
Yes my 33 GTR is dynoing 310-330kw and good for mid 11s at around 118-120mph, with HKS gt-ss turbos at 22psi and 3rd in the OS Giken box. Maybe if I could snatch 4th I'd get a tad more mph. The 32 well.....
I run the 10 on the original setup by Jakes performance tuned by Tilbrook auto with 125 - 130mph. The dyno I was supplied with on car purchase in 2008 was 500+kw on the Tilbrook dyno dynamics. I agree no way it could have been, hence I started a thread back then in 2009 which I have just revived to continue the cars development.
My 32 power at the real confirmed 500kw + level by Willall racing was never run back at the drags to see the real potential of car as I've had multiple failures since then.
For more info on car thread is in the drift and drag section.
I would love to continue the advice and feedback regarding this, but would probably rather do it in that thread as this is the Precision turbo thread and don't want to have my cars specifics filling up a specialised thread on these turbos.
Go have a read at my hell that has been my R32 GTR.
Hi all,
Back again and had the car on the dyno on Monday with the only change being the 600x300x100 cooling pro intercooler.
Compressor seemed to run out of puff at 26psi and tapered off to 25psi by the end of the run which was a bit disappointing. Saw a bit of wheel spin on this run as you can see at the top.
For a $260 intercooler it made a pretty good difference.
Car is pretty incredible to drive, it has awesome low end torque and it quite responsive. Keen to test it out at roll racing in a couple of weeks.
-Ryan
56 minutes ago, r33ryan said:
Hi all,
-Ryan
I'd doubt the compressor is anywhere close to being out, mine is rated at less and puts out 200hp more. Just up the duty cycle top end.
I'd also comment that the graph looks extremely lazy. 85kw at 4000rpm is horrible. There is something not right there, does it still retain VCT?
Edited by SimonR32
As Simon said, something doesn't look, nor sound, right. Though I have never used a turbo the size of yours, most PT's love it at the high side of 25psi and just keep making boost. I am at 32psi and no sign of the 6766 stopping yet
As an example, my 6766 with a 1.0 rear end at 4500 is making an easy 19psi and 420rwkw. I dare say yours should be making more than 11psi and 110rwkwk
What was the pre-intercooler intake temps?  Presumably that was taken if "compressor seemed to run out of puff" was the official diagnosis.
Do you know what boost control solenoid duty cycle is?  This looks almost like what I'd expect if the boost control setup was nearing the end of it's ability, like if you were running too soft a spring for the setup - not that the turbo is maxed out.  That wavey power/boost curve situation is much more of a "boost control issue" than a "maxed out compressor" type behaviour.
Edited by Lithium
Still retains vct yes.
I'm just going off what I was told, I'm not a mechanic and only have a pretty basic knowledge. I'm interested to hear what you all have to say and if there are a few things I can check.
I've seen your build Simon so I did find it weird for the compressor to have run out. Obviously different builds here but still for it to be that different. I was hoping to screw a bit more into it.
I'm not entirely sure on the pre-intercooler temps sorry, just what I was told.
I didn't before you mentioned it, just had a look. Unsure how mine is set. Twin 45mm hypergates with 14psi springs. Pretty sure they are 7psi inner and 7psi outter?
I almost asked if you are running a 1bar spring. In terms of cost versus reward that would be the first area I would be looking at - especially easy to confirm by checking wastegate duty cycle
  • 3 weeks later...
On 5/16/2018 at 8:02 PM, Lithium said:
Nice - any more specifics?  Been quite curious about the SX-E turbos and a few RBs seem to have them but no dyno sheets or hardly even any numbers, yours included now haha
Here is a pic of my dyno sheet ( Borg warner S366 T4 .88 AR) . S1 RB25, Kelford 270 cams, supertech valve train (stock sized), CP pistons (stock bore and compression), Manley rods, balanced crank/ block. Otaku manifold, ID2000s . Revs to 8K on E85 @30 lbs.
As you can see the turbo is pretty laggy to come on. I'm actually in the market for a PT 6466 or 6870. I'm torn between the 2. looking for some advice. The goal is to move the power band to 4000-4500 while still maintaining the current power.
Edited by feedmyfast
added more specifics
Wow that's laggy all right. OK on the track with a close ratio gearbox but pretty useless otherwise. I would like some power from 3000 on...peaking at 4 - 5000 would be fine.
What kind of ecu do you have and does it control boost as well?
As you can see the turbo is pretty laggy to come on. I'm actually in the market for a PT 6466 or 6870. I'm torn between the 2. ooking for some advice. The goal is to move the power band to 4000-4500 while still maintaining the current power.
Ouch, that's nasty - not overly surprised though, the Airwerks S366s are pretty lazy for their flow at the best of times - I've never understood why they have been so popular when a lot of people using them actually could do fine with the 60 or 62mm options.  Going with the open T4 .88a/r housing and putting it on an RB25 is definitely not setting up a recipe for response.
Will you be staying with the T4 open housing?  I'm assuming that's why you are looking at Precision... if so, I'd look at the Gen2 PT5862 or at the absolute max a PT6062.  I'm not sure why you'd go for a 6466 or a 6870 when you are "only" looking at <700whp Dynojet.... unless you are looking for headroom to make >800whp (6466) or >900whp (6870)?
A Gen2 5862 will make well into the 600whp range and be a different car to drive.  If you would consider changing your exhaust setup to T4 Divided then your options for good power and response get substantially better, too.
  • Like 1
I'm running a AEM V2 ECU and it controls the boost
I went with this turbo at first because it is reliable and cheap for the power i wanted. The car was originally a weekend street car and didnt mind the laggy and very lazy turbo. Recently i have been doing more drag / roll racing events so that very late power band isnt working for me anymore. i literally have to chase every race, its a great top end car but down low i might as well be N/A.
Yes, intend on staying with the T4 open housing so I won't have to spend too much money for an already expensive upgrade. I am definitely looking for some headroom for other mods (stroker / RB30) in the future. Looking for a turbo i can run now and not have to toss aside when i do the next setup.
On ‎11‎/‎28‎/‎2018 at 3:42 PM, r33ryan said:
Pulled the duty cycle up today. What do you guys reckon?
Time for a larger spring for the gate OR run a 4 port solenoid (may have missed it, but I'm assuming you're running a 3 port)
Yeah going to upgrade to 21psi springs in twin 45s.
Ill also change the gate pressure source from the turbo to the intake manifold before I put it back on the dyno.
Found the pipe in the white circle that comes off the idle control block that wasnt blocked off either. Blocking pipe must have blown off so it would be leaking boost out of it.
Fixed it up now so  once ive put the springs in and finalized a few other bits and pieces I'll gey it back on the dyno.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
