24 minutes ago, SimonR32 said:
Direct back to back change... Same boost, 30psi
6870 made even more power with extra boost while the 9180 was all out
Yeah not too surprised that the EFR9180 was out, I would 100% expect the 6870 to outflow it - and by a bit of a margin.   The boost threshold however is a definite surprise.   Interesting how some results can vary!   Hard to know what to make of it.
On 4/25/2019 at 2:27 PM, SimonR32 said:
The precision is the ones that comes on way earlier and makes more power...
I'd like to see the transient response make up for that deficit
Which rear housing was on the efr?
  • 3 weeks later...
Hey all,
Bit of an update from late last year.
Precision 6062, built s1 rb25det, e85 etc
Got it tuned last year and it made 431kw @26psi apparently the turbo was maxed out. Dyno dynamics roller dyno.
I decided to change the wastegate springs from 14psi to 21psi, fixed a boost leak i found underneath the intake manifold ( idle control- cold start valve area ), hpi evolve radiator and decided to run a viscious fan again.  Might have been a few other minor changes.
We stopped at 29psi as we were a little worried about the arp 2000 headstuds not handling much more. Turbo seemed to be still going and I think we could have gotten a bit more out of it if the headstuds weren't a limiting factor.
This is on a mainline hub dyno so it is 710hp at the hubs. Still quite happy with the result and I'm sure the 6062 could keep pumping. I attached a video of the run, hopefully it works.
We used Real Dyno hub dyno and Brad Sheriff from Boost Automotive Tasmania tuned the car.
  • Like 2
  • 2 months later...
38 minutes ago, reaper said:
Nope haven't seen anything. I'm trying a 7275 this week and will compare to my old 6870.
What was the 6870 like? I know I could search this post but who the hell knows how far back I may need to go to find a post....
I have a 6766 with a 1.0 rear and I don't know if the lack of driving but its started blowing blue smoke the other day. highly unlikely to be the  engine so it might be time to up the turbo a little
4 hours ago, feedmyfast said:
Hi Guys,
sorry it has been so long. here are the results from my 6466 @40psi. The car is a different animal now, had to get some drag radials to put down the power.
What's the rest of your engine setup?
I also have a 6466 to go on mine.
S1 RB25, Kelford 270 cams, supertech valve train (stock sized), CP pistons (stock bore and compression), Manley rods, balanced crank/ block. Otaku manifold, ID2000s
  • Like 2
6 hours ago, feedmyfast said:
Hi Guys,
Have you raced it? what mph did it run if you have?
Edited by ido09s
Hi Guys,
Ha! That is ridiculous, nice work!  That's gotta be one of the more stout RB25 setups out there, being SAU people will probably make dyno comments but realistically - an RB25 with 270deg cams and 40psi pumped through it on E85 is going to make some serious power :)
What is the spool like?  There is no rpm scale on the dyno plot (NFI why people print plots like that), so a bit hard to tell.   Be very interesting to see how it goes at the strip, hope you have a decent trans! :D
Also very curious to know what the spool is like! Looks like it would be an absolute weapon, good job!
What turbine housing size - also single/split pulse + gate setup?
Perhaps drop something into the RB25 dyno results page
Strong result.
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
    • Yeah Jap import. Fairlady Z then! I'm a bit the same.  They've been on my radar for a fair while but then just impulsively decided to buy one!  Was going to just buy an NA and add turbos to it later but decided to save the f'ing around and just buy the turbo version.
