  • Replies 340
dude, been there done that, i know how ya feeling. lost it around a corner at 70km, hit a power pole, rebounded onto another pole and that was it !! car died, walked away from it and no insurance, it was a 32 gtst.
now i got my 2nd r32, completely stripped the wrecked one and put it all together with the same engine that almost killed me. whole process took me 10 months to do. 1 year anniversary is coming up Feb 8th.
whats done is done, try to salvage wat u can, get yourself together and move on :-(
btw - i was running a gt2530 aswell........coincidence.......???
I'm with you. But you have to admit he killed it in style, could not have done it better myself :(
No, no, no... I was trying to say that we have one less R33 GT-R on the streets now. I couldn't care less how long MINES is grounded for, or how many times he has to give his Dad foot massages to make up for it as a result of his "driving"... all I care about is the fact that *a GT-R has been killed*...
This must be the most exciting threads i've read so far. I can't believe a guy 20 years old wrote off an R34 and then an R33 GTR.
I know its bad it happened on a public road and maybe more care should have been taken, but damn i think he is one cool kid.
There are alot of jellous people around and don't let them put you off. I say your doing well. Who hasn't owned a skyline and broken the speed limit before?
I hope this is sarcasm.... :werd:
Oh i was more concerned no one was injured.
Sorry mate, i've got sympathy for the GT-R, but not much for you. You should just consider yourself lucky that you a) didn't injure anyone else and B) didnt injure yourself. Like others said, a few more K's on the speedo and that pole would have taken the car AND you out.
A car like a GTR demands respect, and while i know we all make mistakes, you really need to learn from them or else there isn't much point in having them. Good luck in the future, i hope you learn from this.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
