No....not that kind of tool.....
The "how do I get this old rubber hose off" thread reminded me about this idea.....so here it is, the cool tool thread.
What are the odd/unusual/invaluable tools you use!
Here is the opening item....
What: Hose Pliers
For: Saving your knuckles! Gets most hoses off, and after 20 years they can be damn hard to budge! Vacuum hoses, coolant hoses, breather hoses you name it.
From: Got mine from the tool guy that came to the show n shine....probably need to find a specialist tools shop
Cost: About $30
https://www.sau.com.au/forums/topic/325161-the-cool-tools-thread/
what: circlip pliers
for: getting the circlip that holds your gudgeon pins in, to get your pistons off your rods (without one id imagine the circlip would fly into the mystical place in your garage where things go missing for no reason).
from: most major auto stores, ebay, or in my case - mates tool box.
cost: $10 to $30.
What : wire stripper /cutter
For : quick stripping of wire ends : these things are Awesome as they make wiring up anything so much faster than a blade or pair of side cutters - zero wire penetration.
Cost: $30
What: My snap on swivel head ratchet.. Because being stuck at 90 degrees is lame..
For: Using sockets on whatever angle u see fit
From: Snap On, Got it when i was a panel beater 5 or so years ago
Price: about $100 I think but f*k me it was worth it
What: Spanner ends that go on a ratchet
For: Undoing bastard nuts/bolts that a socket wont fit and is too tight / not enough room for a full size spanner to fit onto
From: I didnt buy them, specialty tool shop of some sort as a best guess.
Price: wouldnt have a clue, they dont belong to me
wow didn't this catch on overnight!
What: Snap on hose clamp pliers
For: those damn hose clamps that are in stupid place where normal sized hands and/or pliers cant go
Cost: Snap on lol
I've got no idea how that works but I am almost certain I need it! Sooo many hose clamps in hard or impossible places on a skyline.
Got some pics or vids of someone using it?
I have another one everyone needs.....
What: 14mm stubby ratchet spanner
For: Top and bottom starter motor bolt. Just enough space to turn them easily. And if the top bolt is too tight for a stubby ratchet to undo loop a piece of rope around the end and pull down - gives you about a meter of leverage.
Cost: about $100 for a set depending on brand, you really only need 1 for about $10-15
umm i cant find any but its pretty simple to use...its got a jaw at the end of it which u place on your hose clamp, then once the jaw is on the clamp you just squeeze the handle and it closes the jaws and loosing the clamp. then the handle has a lock on it so it wont spring back out so you can put the handle down and get both hands in to pull the clamp off
What: Manetic Pick-up tool
For: Getting that bast**d nut or bolt or washer that has fallen down into the never never land of the engine bay
Price: $10 to $30 depending on specs
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
