How's this for cool tools? I got all this for $55 shipped to my door from HK. Gotta love sites like DealsExtreme. Take a while to ship stuff but uber cheap!
7pc Steel Dremmel Saw Blade Kit
4 piece Stainless Tweesers
3 different wool polishing tips (12 pces each)
6 piece dremmel Rotary File Kit
4 Titanium coated End Mills
and a MicroSD reader thrown in to boot!
On the topic of trolley jacks, a mate of mine has one that has a foot lever on it that you can use to get the pad up to the body, and lift it a bit, which is great if the jack is under the car a bit and you have bugger all movement with the handle.
As for cool tools, I can't think of much that I have. At least ones that are car related and not bike related. Something I plan on purchasing in the near future though is a split collet bearing removal kit.
Fellas, which websites would provide the best deals on Sidchrome/Kincrome items?
Am after a new socket set (a comprehensive one), an air compressor with rattle gun and a few other bits and bobs. Also need a bench top/table :)
Raj try VEK Tools in Smithfield - they always have a good selection in stock. Bunnings stock Kinchrome and Sidchrome too. If you are after a more comprehensive selection though, go with VEK. They are online. There is another VEK Tools in McGraths Hill if that is closer for you. If you are up for a drive there is Hawkesbury Toolworx in Nth Richmond - this one is a bit of a hidden gem, it is a small, but comprehensive, family owned tool shop.
Thanks Terry and Tim. Appreciate the heads up. Will definitely check out VEK - I have been hearing a lot about them.
I read about a few bargins that could be found online - a particular Sidchrome socket set at Repco had a price tag of $300+ and the same set was found online for $190 brand new! So I thought its better to ask around and seek the best deals before spending big dollars.
This drain plug socket is worth it's weight in gold!
very cool....where did you get it? I bought a whole bloody set to get one of those, would love to know where to get one on it's own
I use http://www.transquip.com.au/, good prices on kinchrome. But bunnings is hard to beat for one off items these days. They do guarantee lowest price
  • Like 1
I have to get one of those. Is this the one you got Eric?
DP1314 Teng Tools 13mm Square x 14mm Hex Drain Plug Socket
Is the idea that you then use a 14mm socket on the end to operate it? Dunno why they don't just use a half inch drive hole.
Thanks Eric. And Adam the one I have has 19mm hex on the other end, I've also got no idea why it's not just 1/2 square....I always forget and pick up a ratchet....
Rob I've got something similar and it's invaluable when putting engines back together for the initial checks. In one case it saved me a world of trouble shooting when it helped identify a tiny leak in the turbo water banjo.
Adam, yup that's the one. The hex body is 21mm and 14mm at the end. I need to get a 21mm spanner. I used an impact socket when I could reach, but the trans in the tunnel fowled the GTR front drive shaft. Grrr, had to use an adjustable spanner along side the drive shaft.
But still way better than rounding the insides with a 1/2 inch drive. Amazing how much that 0.5mm makes such a difference in torque.
  • 4 weeks later...
Looks good Duncan, still a bit pricey unless you where doing a lot of them each week, so I'll stick to the manual one for the moment.
I got a set of these http://www.machineryhouse.com.au/D108 the other day, they are really good for notching tube and hole cutting in thick section material.
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
