Hey guys,
The missus is on the hunt for a seat and would like to sit in a few to test them out.
Are there any good places in around Melbourne to do this, say between Brunswick and the CBD?
Cheers
Don't think you'll find anything within the city. My advice would be to go to either Meridian Motorsport (Moorabbin) or Revolution Racegear (Mitcham). These places have plenty seats on display to try out.
  • 5 years later...
Thread revival - any suggestions on where to check out some seats in Melbourne?
I'm looking for an entry level seat to replace the OEM one in my mostly street driven GTT sedan.
I'm after something that can be installed at the OEM mounting points and with a slider but still low.
Should have excellent lateral support in the seat back and bum but not too narrow at the thighs.
Budget is under 1k for seat, rails and slider.
Some initial options are:
Sparco R100 reclining, around $400 (Unique AutoSports)
Cobra Monaco Pro, around $500 (Revolution Racegear)
Velo GP90 fixed back, around $600
Proforce Safety RTS-300, around $400 (VPW), not much info on this online
Sparco Corsa and Evo look great too but start getting pricey.
Any recommendations? Any shops that could help me choose? Should I even be considering fixed back for this type of use?
Thread reviva
well than that pretty much rules out anything but fixed back.
try second hand. not sure what the deal is fitting aftermarket seats to skylines but doubt it will come out of the box (cheap)
some of the shops listed above are closed, but Revolution Racegear will have the biggest range. Concept Racegear near moorabbin airport isnt too bad for the budget racer.
  • Like 1
Thanks! The only reclining seat I've found in this price range is the Sparco R100, which sounds a bit too good to be true. I wonder if anyone's got any experiences to share?
Thanks guys. One more important thing to add to the requirements: I want to run the factory seat belt so any fixed seat would need to have suitable holes on each side plus a shape that doesn't get in the way of the shoulder belt. I'll see what the guys say in the shop.
Ok so I spent an hour at Concept Racegear in Cheltenham today, great service from Stan!
I tried these reclining seats:
  • Sparco R100
  • OMP Style
They were both ok but nothing to write home about, they didn't feel that supportive to me (I'm average height and weight).
I then tried the two ADR approved fixed back seats in the Sparco range:
  • Sparco Sprint V
  • Sparco Pro 2000
They were both a great fit, very snug and supportive, with the Pro having a slight edge with its lumbar support (it's got velcro pads that be moved to suit) and slightly better front edge padding.
Given my budget I picked the Sprint (the Pro is almost twice the price), which is also narrower at the shoulder so it should be an easier fit in the car and work better with the standard seatbelt. I also grabbed a 4-point Sparco harness that I'll run to the rear seat belt mounting points on the track.
Now if anyone has suggestions on how to get this mounted in an R34 GTT sedan -> http://www.sau.com.au/forums/topic/459830-mounting-sparco-sprint-v-on-stock-rails-in-r34-sedan/ :)
Thanks again Lee and Michael!
Edit: Also wanted to add that the side holes on the Sprint are much bigger than on the Pro so it's easier to slot the seatbelt receptacle through.
Edited by V28VX37
I'm sure you'll find a mounting guide on the forum somewhere with a bit of search.
I run Pro 2000's in my car with custom mounts and they are unreal for support.
Easier said than done it turns out, I've been trawling the forums to confirm which rails would suit a sedan.
I've tracked down the following Bride rail on sale:
BRIDE bottom mount seat rail type-RO drivers R/H side for NISSAN R34 GTT, W405mm x D260mm/235mm bolt holes
Details off the sticker: Bride Super Seat - Model R34(RWD) - Type RH - Code N105 - Parts list B
> Can anyone confirm if this rail suits an R34 GTT sedan?
I've found two older SAU for sale ads for 4door Bride rails and they had the following details on the (older style) sticker:
Bride - Model R34 - Type RH (T) - Code N105SO - Parts list SN*1
I can't find a clear answer if N105 and N105SO are for coupe and sedan, or whether the N105 is just a newer version of N105SO?!
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
