These wooden wheel stands are a massive help - had to get the car high enough to get the gearbox underneath on the hydraulic trolley.
Getting closer.
Are you too good for your home?
Bit more gentle coaxing and playing around with angles and shes apples. First time I have fitted up a gtr gearbox, was a bit painful but got the drill down pat now.
Starter fitted up.
And cross member in.
ATTESA reservoir & lines through to the gearbox are in, tail & front shafts are in and bolted up. Entire drive train minus the drivers drive shaft in.
Front pipes on and played around a bit more with battery cable routing at the front where it ducks around the chassis rail. Looks like I can use more of the 34 bits than I thought - should be pretty neat once finished.
Also spent some more time on hooking up wiring in the engine bay.
Can almost see the end in sight.
Haha ok ok - tail shaft & 90mm front pipes. Dug out my old Trust PEII cat back and high flow cat to see what size they are. Not big enough - going to have to organise a new exhaust thinking Midori titanium. May even get the titanium Midori front pipes as well as I might need these ones on my other car due to a few issues. Wanted them originally but heard reports of titanium front pipes cracking - others seem to be using them successfully from what I have seen though.
Fuel tank went in yesterday.
Then started hooking up the cabin to boot wiring. This threw up the first issue with the battery relocation. The hole that works so perfectly is actually for passing through the 4wd pump wiring so I need a new solution to rise the battery cable into the boot. I left enough slack on the cable in case I ran into trouble like this so might bring it through behind the battery to keep it out of sight and neat.
Battery cable hole made and painted, mirrored the one on the other side and looks factory.
Cable through and battery tray back in.
Battery back in place.
Also spent some time on my least favorite area of any skyline - the drivers foot well / fuse box / loom junctions. Got most of it hooked up but need to repair a few of the wires that were cut when the alarm system was installed and subsequently removed.
Not a great deal to report. Waiting on an HPI braided clutch line so I can simplify and do away with the factory dampening system and get the slave cylinder back on and everything hooked up.
Put a new dust boot on as my old one had gone walkabout. Having serious trouble finding the bolts that mount the slave cylinder going to have to source some replacements.
Also got some new fuel hose to replace the old split ones.
Got back on to the routing for the battery cable to get it finished off. Dunked some of the R34 mounting brackets in Phosphoric Acid to get some corrosion off, and hit them with some chassis black chip resistant paint.
In the bay along the rail there was an existing captive nut left over from the rear HICAS gear removal so mounted up nicely. Almost there on the rest of the bracketing.
Cable now ducks around the chassis rail using the R34 bits and works quite well. Just need to finish off the part around the steering and good to go.
Clutch line should be here tomorrow. Then I just have a few other bits buried in the sands of time to track down so I can progress.
  • Like 1
Thanks and thanks to everyone else who has commented! I've been having a lot of fun putting it back together - can't wait to see it fire up for the first time.
Had a thought last night the clutch slave bolts are probably in the starter motor, and the other 35mm ones I have left over are for the starter ....
Watching.....
I was just looking closer at your cage and noticed you did a double cross in the rear tubes. I only did a single tube diagonal in my 32. Now I am jealous of your cage......looks great. I might send mine back for some extras once I have raised some more money......
I would say it's just Andrew evolving what is required / works. My R34 only has the single cross in the rear same with the one I bounced several times on its roof and that held up very well :P
My main concern is retaining the standard dash bar. If this was being used for rally still, I would probably do a dash bar with some more tie in to the trans tunnel / firewall just to keep that engine out of the cabin & keep good space for legs.
I believe I need the Sainz bar as well now to be able to log book / register the cage so will need to get that added at some point.
looking great Paul. Did racepace build the motor or did you do it yourself?
Yep Racepace built the motor. It's a stage 1 / 2.6. I sourced a new N1 block, R34 crank, Tomei oil pump, injectors etc and we used the head from my engine, rebuilt of course and the ancillaries. Turbo's are GT-SS that I already had on there that have only done 10K kms or so.
    • 2001 BE5D Subaru Legacy B4 RSK (3rd gen) EJ208 (pink injector) Twin Turbo 280PS 5-speed manual Full time 4WD "RSK" grade which means all of the above LQC option which means stock rear spoiler  I got it primarily to export to someone outside Japan who was interested. These BE5 Legacy B4 RSKs are going through a bit of a resurgence right know in Japan as they are one of the few cars from the "turbo, manual, RWD/4WD, 280hp gentleman's agreement era" cars that don't require stupid money to purchase. Which for some people might be a good opportunity to get as a base for restoration. If I can't find anyone to purchase it I will certainly be doing that myself over the long term. Why? Because it's properly fast in stock form, handles well enough for a GT sedan, there's still enough aftermarket and (if you can wait a while) genuine part support to make it a restoration candidate (<-- that will only get worse over time so it's a case of do it now or choose get a BL5 4th Gen). Mechanically it's fine, has only 89,200kms on the odometer. The problem with this car is that the body and exterior trims are weathered from at least the last 10 years being parked outdoors. I'm the 3rd owner, the first owner was the one that had it for 14 years and barely drove it, had a low-speed front impact (which didn't damage anything behind the radiator support) and got it fixed and sold it. The 2nd owner put most of the kms on it and parked it outside for the last 10 years, hence the door rubbers have seen better days but if you overlook those cosmetic details, it presents pretty nicely. There is some minor rust on the LH rear wheel arch which I'll have looked at too at some stage.  Also as you'd expect from a car this age, the clear top coat is gone, leaving a satin finish on the roof.  Mechanically it's fine (as you would expect from a car with less than 100K kms) but the steering does feel slightly vague around the centre position at higher speeds. So first on the list is to get the steering rack bushes looked at. There's also the Lock button on the remote which doesn't work, but the Open button does.... it means that the anti-theft system thinks it's always open? It seems like if you open the car and don't start the engine within 3 mins or so the anti-theft kicks in again without any beeps or signals. So if you got to start it after that, it won't. You have to push the open button again. That's how I understand it anyway. Just a small irritation but not a big problem to sort out. There's only one mod, the Wangan SPL muffler. Just a tad louder than stock. It's a really good mod for those who don't want to wake the neighbours but still want to hear a more prominent unequal length header EJ20 sound. Anyway I hope to get all those things done eventually, that is unless someone wanted to import it to their country from Japan (where I live). I'm open for negotiations as I really would like a Skyline... but this will definitely suffice in the meantime 🙂 *Disclaimer: This is how I picked it up from the dealer, minus the stuff on the back seat. I haven't cleaned the engine bay or done a thorough exterior clean, aside from spray painting the wipers.
    • Wow, even with the Audi logo centre caps. I love OEM wheel mismatches.
    • Welcome!  Can't go wrong with a Stag.
    • Looks good. Nice height.
    • Hey all, a little help from the Stagea hive mind plz.. I'm days away from buying either a 2002 Stagea 250tRS AR-X Four, premium leather, power seats and all the old switches etc that go with it, or a 2002 Stagea 250tRS VR-X Four AERO, pov pack, cloth seats etc, with coil overs, sports zorst, comes with original zorst and suspension and parts. (I think I've got the models right?) Both are VQ25DET, have 160000kms, both straight no rust both with $2000+ in recent servicing receipts, both ride on aftermarket 18" rims. The Aero has a replaced turbo as well. I like the cool factor of the Aero car but the AR-X has never been modified. Neither have been driven hardly at all in the last 5 years. Any thoughts on which one or does it come down to personal preference? davemoto
