Well, the old girl did her first track day in 3 years on the weekend!!!! Cant believe it had been that long and I sure as hell was very rusty at trying to coax the thing around a tight and twisty Winton.
Will post up some vids when I get a chance to edit them. Didnt really lean on it too hard, wound a bit of ignition out of it and didnt rev it to over 7,300rpmish. Grabbed some second gear and rang its neckto 8,800rpm limit a few times in the slow twisty part but the engine breathed about 500ml of oil into the catch can when i gave it that hard a time. Didnt breath a drop of oil when I went back to using 3rd gear through those slow corners....so something to consider.
Wasnt overly quick, but was a good first time back at the track , car really needs a wheel alignment and ride heights set....that itself would make a huge difference.
Its not that brilliant a time but I am stoked with it. I didnt look at times until the next day on Natsoft though a few people mentioned that I was in the 38s. The day was about getting kms in the seat and the car to see if there are any little things that need sorting since it has been in pieces and off the road so much. But tribute to Racepace that the car ran faultless all day and engine was strong, handling was nice and neutral....i was stoked with how easy the car was to drive.
So from here pretty happy that all I need to do is set the ride heights, get a wheel alignment more suited to track work with semis...and then its just seat time for me.
The other thing is the vid is of the only dry session on the long track. Was good to do some laps in the session before in the wet to get a feel again for the flow of the circuit....but only getting 4-5 laps of dry running and getting the time I did....I am stoked! Even the tyres despite being a few years old appear to have been stored well and had plenty of grip and probably the car was quicker then me (as always)
Nice video!
I would kill myself if I had a HKS BOV, I just can't stand that noise haha
I also found my RB20 hard with top of 2nd gear corners, as soon as they come on boost they just want to go sideways and moderating the throttle doesn't really help :(
The top of 2nd gear is just a driving thing. Like any rwd car with a decent amount of power, you just need to take a line through the corners that allows you to get the lock off as soon as possible and plant the throttle when you are close to going straight.
Well the new cage is in....Risking has done a nice job and on teh drive back to Melb from Sydney was nice to be able to recline the seat and take a nap...the cage fits the b piller a lot nicer then my old cage.
Over the next few weeks I suppose I need to put more effort into my interior and throw some dry ice in there, strip it and give the whole lot a lick of silver
There isnt a lot to be gained from chaging it to a full race car?!?! I spend 10-15k more on it to go maybe a fraction quicker and drive it less. Right now its about right with regards to usability and my budget....and its still fun which is all this car is about. I dont think I would enjoy racing, it costs too much, talent (the biggest part) is missing and dont have the time and space for a race car
i like it. Club Racer spec. id like to build a car to that sort of spec one day. build a car that is still street legal, or there abouts and race it/drive it as often as i can and be happy with the comprimise. thats the biggest hurdle for someone like me, being happy to compramise between not the best street ride and not the best track setup. a car with a pourpose.
on the interior side. ive seen people use carpet like sub box carpet to lay over the bare rear section of the car to make the car feel a bit more user freindly. HPI had a GTR from dubi that had a carpeted rear and it looked very tastefull.
I like the clean look of paint. But I like the practicality of getting it all carpeted as it reduces glare in the sun, more durable when throwing tools and wheels back there, also reduces road noise a tad. Will most likely paint it, simply because I do prefer the cleaner look, but will have to look at the cost of it. Panel beaters charge a fortune and I do want it colour matched to my external paint
Yes Pete, saw the 31 and had to shake my head. Not because its not mega cool, but because you have so many projects on the go that I just had to laugh and think that you could be just a tad bipolar.
So the Plazmaman plenum is finally on. Went for a drive and it obviously has changed the air flow of the engine as the tune seems out and will be getting tuned next week some time. First impression is perhaps the throttle response is a bit sharper, but it is already laggier. But that is untuned SOP feel and I now have a Blitz ID Spec R on the thing now which still needs to be setup. SO....not sure yet.
But at the moment it better perform as the following means I am not all that excited about the install of it. Firstly, you need a small battery, no way a std battery will clear the throttle body location. Second is the Cusco brake stopper has to be removed as the plenum fouls on it. It was expected that you have to extend the loom a little for the relocated throttle body. The std throttle cable was fine. The angle off the front of the throttle body isnt great with trying to get it back through the inner guard. You lose the bleed point for the coolant system. You lose access to your dip stick, you can still reach it but its a pain. And its NOISY. Sounds like you have a massive leak as the alloy is so thin that you hear the air rushing through it. Not a bad thing, but just another noise in the engine bay you have to understand and ignore when you are diagnosing things.
So thats about it for now....will see how the tune goes. The cost of the plenum install means its staying on whether its good or sh1t. Hopefully the tune yields positive results, if so the 256/8.5mm cams go in. If the tune reveals no difference or a backwards step then I am going to give up on the lil 20 and just wind 22psi into it and have fun with it and start building my stroker full of Tomei goodness :)
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
