  • 2 months later...
So just got back from Le Mans, Goodwood Festival of Speed and Burger RIng. Pumped more than ever to get the underside of my car back in. Still trying to suss best solution to HICAS delete on my new rear cradle and then slap the whole thing in.
Have gone to rather stupid lengths with regards to replacing things that didnt need replacing...but I want to just bash the old girl senseless the next few years like when I first got her with no fear of breaking things and or worn things crying enough.
So, to keep motivation up will be posting some pics....but in the meantime...why I am broke at present
Le Mans
10309403_10153028237434741_5458988814510
10463915_10153028233879741_6281357194627
10379003_10153028234139741_4174118686847
10524351_10153028236324741_4581860243387
10492456_10153028236049741_3525409114684
10468681_10153028238164741_1044204237288
10550972_10153028238759741_6120609531028
10448832_10153028238599741_7788646528147
Better pics taken by my mate Jarrod https://www.facebook.com/pages/JRM-Photography/208118185886748
  • 1 month later...
So posting this here as I have the option of removing it now from the car now whilst its off the road.
What are peoples thoughts on value of this ultimate RB20 looking sleeper:
- R32 RB25DE block, crank and head
- CP pistons
- Eagle Rods
- ARP head studs
- std oil and water pumps
- Tomei 256/8.5mm cams and cam gears
- Tomei valve springs
- Plazmaman Inlet Plenum
- 6Boost Manifold and Turbosmart gate
- Genuine Greddy T67-25G
- Xtreme Single plate clutch
- RB20 gearbox (210,000kms)
- ID1000cc injectors
- Tuned AP Engineering RB20 Power Fc inc Z32 AFM
- inc Splitfire Coil Packs
Can include comeplet loom too if folk are thinking S13 conversion or something
So how much so you reckon I would be able to sell the whole show for? Engine, turbo, injectors etc all less than 5,000kms old. Gearbox and clutch is really the only thing that is tired. Still works fine with no noises, doesnt jump out of gear etc but is obviously at its limit and has plenty of kms on it
Graph is off the wastegate with no EBC and quick safe tune
398854_10151838547609741_1680740710_n.jp
Really need the cash for the Judd V10 and transaxle I am putting in it :) (I wish)
  • Like 2
  • 4 weeks later...
Hey Roy, I have just spent about 3 weeks reading this thread from start to finish whenever I get some spare time. Fantastic build thread dude, was such a good read...Hope you keep us updated. I too am a lover of the good old 20 and I'm now working on getting mine ready for the track, I also got mine bone stock and I've got a garage full of parts waiting to go on and with some money to get it all fitted up and tuned I should have a 300hp track ready r32 by the end of the year :)
Edited by AzR32
White R32s are yummy. There were a few colours that I considered when I got my car sprayed and it basically came down to white or silver. Still not sure I got it right
With a good tune the lil 20s can take some abuse and provide a load of giggles
So got more stuf back from powder coaters, More bushes and bolts and nuts and washers etc and damn close ot having alloy hubs in the front of my car. Such a waste in hindsight to go to the lengths I have but meh...is what it is and will be good that it is so neat when its done
Before
AFTER
Had the uprights blasted, zinc coated (in case powder coating cracks over time) and then powder coated in a rather dull but very durable silver
Going for silver and light pastel silver powder coating as I want all light colours so its oiss easy to see tell tale leaks and drips etc.
Had a little porblem with the new ball joints. I am telling me this is typical but not happy so going to get some 42mm shim washers and pack the gap between the arm and the circlip
  • Like 1
  • 1 month later...
  • 1 year later...
So 2015 was largely a write off. Started a new job where they work you like a $2 pole dancer and combined with putting myself on a tight budget of $500 a month means things move very slowly :(
But, finally got to a point where the new rear end has been fully refurbished, new shocks rebuilt by Racepace and now just need new springs. Custom tops that will heopfully be mega quiet for a loooong time. Got the new diff, suspension arms, fuel system etc all sorted now.
Problem is I lost a lot of motivation last year when I sold my T67 setup so have now got my new twins and close to getting all the bits I need to get it all bolted up to Kinda surprise.
Here are some pics of the retarded amount of hours I have spent welding, painting, pressuing bushes and bearings in the hope that the car will drive like new when it finally gets back on the road.
So the reason why I binned the old R32 cradle. After years of flogging around tracks it gave up the ghost
So when sorting the BCNR33 GTR rear end I decided to gusset it all up
So after welding it up I paint stripped the whole cradle, wire brushed it and went a little bling with the silver
So whilst working my way through the suspension re-bushing/bearing everything that could come out I decided to get carried away with painting stuff. Partly so that all teh light colours will show up oil and partly so I could strip any parts I was re-using and inspect for cracks etc. And partly that it will be nice for the car to be clean and neat for the frist 6 months that its back on the road
Got some chrome moly pipe cut and threaded to the length I needed for my new front LCAs and had them coated before painting them
Going to the R33 GTR rear end meant I had to get a new diff so went for a Nismo GT Pro 1.5 and grabbed a Trust diff cover to give it an extra bit of volume in attempt to keep the rear end consistant over 10-15 lap sessions without going for a diff cooler. Who knows if the extra volume actually makes a difference, a Trust bit is cool all the same.
And with the rear cradle about to be all bolted back together and into the car I have the new gearbox cross member to allow me to throw the RB25 box in after givign away my RB20 box to a mate with a 260rwkw SR20.
  • Like 3
    • If you are Ecutek tuned then these TCU tunes are anywhere from $550 to $700 usd. If you are not ECUTEK tuned, then it gets costly!
