I will be back, but probably not this year. The car is currently stripped so I figure I should meet the new tarmac rally cage regs before I put it all back together, whatever they are.
Might drop by for a beer though, it is just up the road these days.
  • Thanks 1
  • 5 months later...
Happy New Year ppl
Got myself in a bit of a mess. Can't fund a new 350Z DBW pedal locally so sort of stuck with what the next best option is. Want to ensure pedal position is at least as  good for heel-toe as factory
Measured up the std inlet and seems I need to make do with 400rwkws through a 60mm DBW Bosch throttle body
  • Like 1
Nissan X Trail or G35 Skyline (plastic pad not alloy like the 350Z).
You'll need to drill 2x new mounting holes on the pedal bracket itself (same as the 350Z) and then manipulate the pedal rod itself in a vice till you're happy.
Here's mine after I sent it, note this is an older photo, I've once attacked the pedal and it sits a little lower.
+1 on the IEE option. He also has some of the right size grommets to block up the hole in the firewall. I would have done this over the 350z pedal had I known prior.
Edited by R3N3
  • 5 months later...
So Bathurst coming up so really need to get this new ECU in. I regret going to flex fuel and all the headaches associated with DBW with cruise etc....a miss the simplicity of Power Fc :)  I make enough power that I should have just gone back to 98 but...anyway
Turns out with the std inlet I cant really go any bigger than 60mm DBW so wasnt able to play with that aspect of the update.
8 hours ago, Roy said:
Power FC is all you need.  All this extra fluff I'm installing is very masturbatory...
With the car off the road again there is waaay too much playing with something
Till the new ecu saves your engine with its engine protection and then you realize it’s worth double what you paid for it
  • Like 1
Lol, yeh...the things we tell ourselves. I slap my motors together myself and havent lost one yet. ECU setup is worth 6 times any motor i have built....lol so....yeh its masturbatory  :)
Help me Steve, got an Emtron KV8 and thinking P14 Black Box with C127 or AEM ED7/ CD7.  Ive got my old Aim MXL and Race Technology DASH2 so no rush for dashes; next step is PDM with PWM as i still street drive the old girl and fuel does warm up with 550l/min cranking through the lines just potting around along with thermo fans
Lol justvspent 14hrs doing my wiring diagrams in CAD to help work out wtf im doing :)
  • Like 1
  • 10 months later...
Ok...its taking me long enough to finally do this.  Feck financial security...heart disease will get me soon enough anyway
So welcome to the garage..."Clem"
Belsil80 has been running a 370Z in Super TT series. So after entering with him in last years Winton 300 i figured I  need my own car.
Seems SAU Vic race cars need to be yellow....{tick}
Reckon with enough motor i will be able to make up for the lack of talent and stay ahead of the 370Z... but the LS powered S13 and E36s are a ways up the road :(
Aim is to have a car that doesnt stop or turn but has a bit of shed built motor with jam...maybe some cream :)
First step is getting this ex drift car log booked
I am keeping faithful silver car. As the road-club car gets upgrades the race car wil get the sloppy seconds :)
  • Like 9
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
