  • Replies 467
And just as a sidenote, what do we all think of the ARC airbox ?
meh. I used to love them. I bought one. the internal bell mouths are ok but could be a little better. the big problem is that it's bloody heavy and is right up the front of the car and nice and high too. that's the last place you want weight in a GTR. the other problem is it just sucks air from inside the engine bay just like a set of pods does so I can't really see any advantage to it over a set of good pods. and in fact pods with a shield are probably better. plus they are expensive to buy, and expensive to maintain (filter cost is through the roof). you can replace 2 apexi pods for $120-$160.
so personally I wouldn't use one.
Tend to agree, the weight being the main reason and they just take up So much room. I think they're efficiency is ok, as I'm not a believer in the neccessity of CAI for turbo cars.. They do tend to appeal to people who like glitter and stuff though (no slur, just observation).
I have a "real" mandrel bender with alloy mandrels and bend up cooler piping up to 3.5 inchs regularly.
it would seriously cost 200 bucks in materials to bend up a nicer set of pipes to suit a GTR plus the silicon joiners and a couple of hours labour.
I can't see how they justify that kinda money for a piping kit that's mass produced.
Oi
i'll have to grab that light soon! you still working with greg?
They justify it because not everyone has a mandrel bender, the skills, the time, the patience, the Mabo, the vibe......
I would rather spend $2k buying a bender and learning how to do it rather than pay for a Nismo pipe kit; then develop patience, Mabo, vibe... etc
HEY! Don't look at me, I run China shit! Added benefit besides costing $200 INCLUDING the bloody cooler is that it's light, coz it's such thin wall crap :)
Still works just fine though! :P
HEY! Don't look at me, I run China shit! Added benefit besides costing $200 INCLUDING the bloody cooler is that it's light, coz it's such thin wall crap :P
Still works just fine though! :)
Lol... Marlin you have a great attitude! :D
It cost me $263 shipped for the 2x ARC Filters needed :( i wouldn't be using one if it didn't come with the car.
Coilover come today, Anyone know what the best height for the gtr is?
2k will buy you a really nice quality die set bender that will do the job perfectly!
As well a plenty of other shit too!
I used china hks type pipes on my old car. They worke fine
brad what die set bender would you recommend?
for starting height, i would have thought standard ride height would be better than anything, assuming nothing has been drastically changed initially.
He does make a very good point......
hehe, and he didn't tell us what he has decided overall unless I'm mistaken.
Although - to the defence here, it might have been posted somewhere in the 11ty pages of this thread? :(
Suspension, rim size, tyre size, spring rates - the works needs to be known.
Hence i still reckon visiting the local track on a "GTR" frequented day, go from there :D
fair enough
17inch rims with Advan AD08 255/40/R17
Spring rate not 100% sure need to double check and try to cal the spring rate or get off my ass and order some 8/6 springs (or was it 8/7 cant remember now....)
Reason i ask because when i got my tein RS it came with the instruction and tein had what they stated as the best ride height for the coilovers and gts-t
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
