Hi all,
Unfortunately recently my r34 was written-off.
So now I am in the market for another turbo car but want to spend around 10-15K.
Any suggestion?
I would like to get peoples ideas on this to help me choose a car. Thanks
https://www.sau.com.au/forums/topic/335947-what-sport-car-to-buy/
  • Replies 52
you probably don't want another skyline, so if you're after something punchy i'd say the best value 'sport' car in that price range would be a mildly modified 200sx.. you can get s15's now for 15-16k... newer and better on fuel than the skylines :) or if you're happy with an older model, there's plenty of s14 series 2's under $15k.
what about a 300zx tt they go pretty hard
Yeah, pretty big power from factory. For $15k you'd get a really good one. Probably forged rebuild with 300rwkw :)
Even mine came with a new engine and I only payed $8k.
Only downside is all the jokes that people make about them :( And they actually are kinda unreliable and a bitch to work on.
Another suggestion (even though I'll probably get flamed for it) is an MR2 turbo. Get a 94+ with the GEN3 turbo engine. They go surprisingly quick!! Great handling and heaps of traction thanks to the mid-rear layout. Nice and reliable too.
If you want to go down that route let me know and I can point you towards some nice ones. $15k would get you a really good one!
Edited by jezza boii
For 15k your could get a tt supra if you shop smart..
I sold my NA Supra for that price :D I don't reckon you could get a decent TT for that price. I've seen some mint ones sell for 30k - 40k+
i dont get it :D ..i was being serious..my mates got one and i reckon its pretty good minus the tight engine bay
oh, i thought you were being sarcastic was well played.
please show me where id grab one for that
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
