  • Replies 270
If it is anything like the beastly unit he made for me or the even larger (!!!!) dump pipe he put on his own M35, you will certainly notice quite a difference :)
hehe hope thats the one i got .. because mine is large and spiffy heatwrapped ^ :D
big :( scott.
btw scott.. hows our dolphin replacements going for that turbo inlet.. tell your wife we need you on the mig! :)
Edited by PetroDola
Dolphin? bah!
My intake craps all over that one. :P
I can make it whenever you want buddy...
awesome - champ!
from what i understand also.. the dolphin upgrade isnt mission critical its the other piece you've welded up, although i understand the dolphin helps marginally with the flow rate.
im looking at rebuilding this turbo to be ready by late dec/early jan depending on how long they take.
so anytime around then would be awesome?
and what do you want for one?
Cheers
Keir :D
Edited by PetroDola
Angus,
Put me down for one mate. My preference is to have it looking factory stock for the ceramic coat..
To all the others who fitted theirs by themselves:
Oh and I don't have a hoist, but it sounds like dropping the gearbox X-member is the way to go.
Can someone detail the steps to go through?
Dropping the gearbox x-member is not required.... even without a hoist.
Just get it up on ramps/secure axle stands, undo the front pipe at the dump (2 bolts) and f**k around for sometime trying to get all 5 bolts/studs undone so you can remove the dump.
Some swearing is recommended for release of frustration :whistling:
Oh, and make sure you do it when the dump pipe is cold!
Lastly, WD40 is your friend
Edited by iamhe77
Bends have been bought! flanges are being cut! we're moving along in the right direction!
What kind of coatings do we want? the dark coloured stuff or the polished look?
Champion effort!
By coatings, are you still talking ceramic?
I don't know about anyone else, but I'm not expecting enter a car show so the only way anyone (other than my mechanic?) is going to see the pretty "polished look" dump pipe is if I roll the car in a ditch and it's upside down.
So I'm not overly concerned, except darker sounds like it's less likely to show up my grubby fingerprints, and those blood stains from my knuckles from trying to fit it..
Some swearing is recommended for release of frustration :(
I made my own Stainless dump pipe for my 1600 and getting the F&*(^King 02 sensor off while in the car was made extremely easy by dropping many F bombs... Don't worry I'm fluent..
Sounds like a good job..
Might take some photos and add to a build thread on here?
Yeah no problem, the coating is the ceramic, Andy said there were some heat issues with the last ones, passenger feet getting a little warm so its a move in the right direction.
Sounds like Black coating it will be!
Not looking forward to finally fitting my one once they are done either! it sounds like your typical nissan dump pipe.. dont plenty of gtr ones and they are so annoying.
Anyone know if this sale item is a replacement of the standard dump pipe and part of the standard front pipe that attaches to it?
http://www.importmonster.com.au/view?url=h...0NM35%20VQ25DET
It looks like it could be.
The problem that I can see here is, pipe dia. off the dump is 2.5" so you're not getting the best possible flow, and you will also need to cut it and fit a cat about halfway along that pipe if you don't want to get a fine.
Add to that, I would recommend a flex bellows off the flange before the bend. By the time you have this delivered to Aus, modify it to suit, you would've been able to have a custom pipe made EXACTLY how you want for the same dollars.
Edited by Daleo
    • Even with the piston at TDC there was room for it to drop, but I don't think it can drop fully into the cylinder, the problem you have is that you need something pushing against the valve to hold it up so you have enough room to put the new stem seal on and the spring etc.  I used compressed air only because putting rope in the cylinder seemed a bit risky to me, I know people have done it countless times before like this. Overall it's a pain in the ass job. Honestly you'd probably be better off taking the head off because the risk of dropping something in the engine and the finicky-ness of it all is very stressful. If you are going to attempt it though i 10000% recommend a 36050 valve spring/keeper tool. I had both the traditional lever type and after doing 1 cylinder it was absolute pain to get those valve keepers in place, even with 2 people. That 36050 is amazing, you do have to push hard to get them in place but it works perfectly almost every time. Back to my actual issue I think my engine is just tired and old and the rings have gone bad. The comp numbers (cold, no oil) were: Cyl 1 -129psi Cyl 2 - 133psi Cyl 3 - 138psi Cyl 4 - 137psi Cyl 5 - 157psi Cyl 6 - 142psi   Cylinder 5 and 6 having the most carbon on them.
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
