jump in a 400kw+ gtr and you will realise :laugh: If you havent experienced it, how can you understand i suppose. 300rwkw to me seems abit slow and not that exciting like it used to be years ago when it was the fastest car i had been in.
Agreed, the acceleration in your 430odd kw animal was quite special. I need drag radials to put the power down anywhere near as well, so as a street car they don't compare. Then again my gearbox isn't worth 10k haha.
  • Replies 250
Posted Images
There are people who strap on big turbos for the sake of saying they have a big turbo, most of the time on a mismatched combo and mismatched application.
Creating peak torque early and sustaining it as long as you can is where its at. Alot of research and trial and error is involved to achieve this, most people either lose interest, settle for what they have or simply run out of money :laugh:
having owned peaky n/a 4 cylinders before, having any torque is great for me, so my goal is to get as much torque and as early as possible, this will also suit the type of motorsport I want to get involved with, where response and punch out of corners matters most.
Couldn't f**king agree more.
On the street?
You know, where 99% of us do our driving :laugh:
I just came back from a DECA day (motorkhana) with my new GTR (350rwkw)... Not one car launched harder/faster.
This included blown Monaro's on slicks that I believe run 10's with relative ease :banana:
But yes, power is important to an extent - power delivery however is IMO the most important.
lol @ slicks @ DECA
Not to get too far off topic, but it's not only off the line. So many times through twisty roads they can't get power down out of corners (and I'm not talking hairpins), yes in the drag world rwd with tubs and slicks is quick but who drives that on the street, this is more about realistic street cars than purpose build racecars with no rego
What I find funny is how people making comments such as the ones in this thread then they go in a fast gtr and all of a sudden they change their tune so to speak.
Anyway back on topic, do what feels good and as long as you're happy good for you
This man, is correct...
I was running "250RWKW" or so the dyno claimed (Injector Duty Cycle and AFR claimed around another 100RWKW), and even sitting at 130KM/H on semi slicks, I just couldn't put that power down without rolling off the throttle as it came on boost...
On the street tyres it even turned them in 4th if you quick shifted 3rd - 4th.
If it were a GTR, it would have started to spin, attessa would kick in, and it'd be all over... Although, there's nothing like giving it a big crack of throttle for the first time to overtake and ending up sideways trying to grab 4th... Sorry Mr Baxter... but your ute just didn't keep up!
The whole point of doing power upgrade is for the "power".
Generally any thing that can boost 20psi around 4000RPMs is pretty drivable for the road. So a turbo that can produce the max amount of power within that response range is most acceptable. On the same time you can get some cam gears or cams to advance response for better driving ability.
My mate a few years ago went for a drive with me in my 427rwkw GTR and could not believe the acceleration through the gears... He owns a R32 rwd that runs a 11.1 at 127mph
They don't compare, if you think they do you have not been in a GTR with decent power. The difference between 300rwkw to 370rwkw is phenomenal, going from 370rwkw to 430rwkw is going into another reality!
Edited by SimonR32
agreed, on the strip in RWD with decent rubber he might run 11.1 but on the street would just fry tyres if he even thought about planting it,
300KW GTR can run 11.3 with a good driver
370KW GTR runs 11.0ish i think on the road they feel stronger, most cars with lag feel really fast once on boost especially cause they hit right when at the max torque of the motor.
The way i see it, power is a by-product of torque so i look at power anyways BUT at rpm points.
+1 Power is calculation of torque and rpm.
I think your title should be "Is the peak power figure everything or is average power more important".
Peak power means stuff all in a street car,
For example, how many dyno queens have actually run a quick time down the strip?
I can think of 2, Eddie Tassone's VH commodore (Twin turbo 383ci V8) and the Trick and Mansweto Capri (604ci NA V8)
but these were both built as drag cars from the outset.
yet a heap of other cars have made big power but are useless at anything other than being strapped to some rollers.
PM-R33 is right. dyno's torque measurement is highly suspect. and the simple fact is power = torque. yes the exact numbers can vary but there is a very fixed relationship between power, torque and RPM. so unless your car makes it's 170kw at 2,500rpm it's torque production will not be fantastic. given all our skylines rev to somewhere between 7500 and 8500rpm and all make peak power somewhere above 6,000rpm the amount of torque produced wont vary massively form car to car with similar amounts of power. ie. if power is the same, rpm is the same. torque will be pretty close. you can move the curve around a bit with different tuning techniques and different parts but the peak won't change too much.
Agree. The torque won't be 457Nm, but it should be a touch above 400Nm (at the flywheel).
Area (depends on gear & shift points) under the curve is EXACTLY where it is at.....this area = energy.
At the end of the day when your standing around the BBQ if yours has 10 more killer wasps you instantly gain 10 more inches
*ohoh but mine has more power under the curve*
It will get you nowhere.... till you see them at the lights :D
most people wouldnt even understand what "power under the curve " means ..including me...
Just sounds like another excuse for losing,So what does it mean?
Cause the more excuses i have for losing the better :P
Average power, or the total area underneath the little red line on the dyno print out.
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
