Next event is in Grafton 6th/7th June mate and then Tamworth on July 18th/19th.
I have conned Duncan into coming to the next 2 long distance events,,,.He needs to work less and enjoy some racing for a change anyway.
Mel is getting lazy these days and I can always do with the help.
Cheers
Neil.
lol you better hope Mel never finds out the internet exists....I refuse to replace all her roles for you. Even if you take me to dinner first.
Mel doesn't give a shit to be honest mate,,,she just likes taking trophy's to work and sticking it up her known it all technicians.
So what are you saying,,,sounds like I should have gotten hired help,,,maybe I can find a stray or two up there.
Cheers
Neil.
I need to try and line up a weekend I can head up on one of these events again!
Unfortunately neither of those weekends is likely to work for me :(
What's your next meet after that?
So as usual I'm back into weight saving mode. This excellently crafted thing by Nissan has to go. It weighs in at 2.7 kilos.
To do it I have bought this, but I think It may not fit properly in hindsight.
So I may have to buy one of these
While I was at it I thought why not ditch the steel case around my Odyssey battey,,,took a bit of work,,,but I got it out without damaging the battery.
So thats a saving of 3.3 kilo's. I'll maybe add about 300 grams back in the battery holder,,,but 3 kilo's is a great result.
Cheers
Neil.
Well Matty, after Tamworth is Ringwood 8th/9th of August,,, which is by far the most crappyest climb on the calendar. It's on par with Collingrove in S.A.!!!.
Then Huntley on the 13th of September,,,then King Edward Park on the 4th of October.
The Aussie nats are on the 6th/7th and 8th of November in W.A. What about you and Sarah drive all my shit over there and I'll fly over and meet up at the airport. Sounds awesome to me.
Cheers
Neil.
Gee thanks you two mutherfuuckers,,,ones calling me a poof and the other wants to pelt me with 1/2 cut lemons.
Actually Jase I'm off the VB's,,,still not on the fancy catspiss like Fatz drinks,,, just good old Carlton Draught.
Cheers
Neil.
Cheers
Neil.
:laugh:
Ah well its 5mins from my house so if i remember ill come down and sabotage the opposition for you :yes:
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
