here is a video of the fastest auto-x run of the day, you can hear our coilpack working, then not, then working then not. soo frustrating, I can only imagine how much faster we would have gone without the miss
the ETS-pro is great, you can see at the launch that all 4 wheels are spinning, and then at the end you can see a perfectly controlled 4 wheel drift
Are there any other EFR 9180 results yet? (Besides Sierra Sierra)
And can anyone confirm that the Indy cars will be using these turbochargers and if they will be any different from the production version available to the public?
Yes - I can confirm all 2012+ Indycars use a 100% off-the-shelf EFR rotating assembly, the same exact turbine and compressor wheels / shaft / bearings that every aftermarket customer will receive. The wheels are literally 9180 and 6758s. The only difference is indycars weld the twinscroll housing to their headers, so there is a different inlet (i can post a pic if you need to see). for the twin turbo chevrolet engines, they get an external WG t25 housing for the 6758s (this is so teams can not cheat and raise the boost). same center sections however
2 races completed, no turbo failures (edit for the haters!)
Edited by Full-Race Geoff
Anyone know if Penske are running the Single turbo or the Twins?
penske is winning because of their suspension/chassis perfection imo, the turbos were within 1/2mph of one another. here is a photo, you can see the penske dampers and the twin EFR 6758, stock center section complete with internal wastegate mounting holes in these 2 photos:
chevy twin turbo:
Lotus twin turbo here:
Honda is running the single twinscroll turbo:
note: honda is the only team using "header bags" to contain the heat. chevy and lotus just use raw or coated tubular fabricated headers.
Is there any indication when the lead time will become weeks instead of months?
I do not know the answer to that question yet, BW are hesitant to give us anything until tracking numbers are ready. We will certainly let everyone know the updates we receive.
Geoff, are the Indy cars running antilag with these turbochargers? Also, do they have a use program i.e. after one race, throw in bin put a new one on?
A twin EFR 6258 would be cool with external wastegates... just not much room!!!!!
Geoff, are the Indy cars running antilag with these turbochargers? Also, do they have a use program i.e. after one race, throw in bin put a new one on? A twin EFR 6258 would be cool with external wastegates... just not much room!!!!!
mike, my understanding is that indycars are using their own unique antilag system, it is not the rallycar wrc style air injector valve style
everything for these teams is regimented and methodical, typically the engine and turbo are serviced together as a unit and my understanding is that they only change the turbo if they need to change the engine. anybody watching the races can clearly see there were no turbo failures or teams frantically rebuilding their motors during any of these races
excellent wastegate placement on those cars!
So Geoff, after your first outing, any regrets on your choice of turbo size and rear turbine size? Any plans to test different turbo/turbine combos on this car?
Edited by black bnr32
I am daily driving the EFR 8374 internal-wg on my 2.0L twinscroll evo street car for 2 months now so it was a lot of fun to try the external gate on my 2.6L RB26 it is another animal completely. We flogged it for 4 days straight and i drove both cars on the local streets and highway at different rpm points and loads. I know this RB26 engine/head/cam combination very well (had it for years now) so i can confidently say that no turbo has worked nearly as well as this unit. Of course i really got my chassis sorted which helps confidence at speed, but biased or not this is the best setup ive ever felt in the car. My driver for the autocross was a long time friend from engineering school who competively races 997tt porsche and mustang v8 autocross prepped cars, he calls my car "the easy button" just punch it and instantly the torque is up, very driveable and forgiving
One particular comment is this turbo's powerband works well with the 5 speed r32/33 transmission and 4.111 fd. I no longer feel obligated to swap the R34 6 speed box in (I wanted to save the 6 speed for my dedicated race car anyway). On all previous turbo setups i felt the 6 speed box was necessary. Torque comes on so much earlier and stronger with the EFR, huge improvement.
My comments/thoughts are:
-i prefer the internal wastegate EFR 8374 .92 a/r. to me this is the cleanest and lightest weight way to run this turbo. On my evo i absolutely love it - not once have i wanted external wastegates. the amount of work required to properly recirculate (2) external wastegates is no small feat. I invested HOURS into this, and will never offer recirc'd external wg's for customers... it literally takes that much time. If its a serious dedicated race car however, the external gate is the way to go.
-since im already on the external wg twinscroll T4 config, im extremely interested to know what the 9180 does to the powerband? that will probably be the next turbo i try, if its as "magical" as the indy guys say i might keep it there and not go to internal wg 8374
-my next major change is to use the proEFI ecu and get wider rear fenders. On the 275 street tires it is easy to do 4 wheel burnouts from the EFR turbo and ETS-Pro center diff controller. Using the proEFI traction control combined with the efr turbo and ets-pro i believe we can have one of the fastest street tire cars in the USA, my goal is to run the 315/30/18 and then pro-efi traction control to put it all down. i cant imagine any rwd cars being competitive there, we will see! maybe if we can get our act together and make it to WTAC 2013
Yes give that 9180 a go on some pump fuel please Geoff. The only equivalent would be a 67mm S400SX correct? But from what you have outlined that is more of a class drag racing turbocharger.
Finally booked my car in for a tune next week.
Should have results for the 6258/SR20 combo next Tuesday. :)
Ohhh I'm excitement!
If I don't BIN my SR before then you may sell me! Here's hoping man.
P.S. I take it that the wiring stuff we discussed worked out?
Didn't get around to wiring it in unfortunately. :(
And being one of those things that could quite easily turn into a massive clusterf**k, I've decided to put it on the back burner for now. Got a track day on the 16th, which I am not under any circumstances going to miss...
As it is, the car still hasn't been started in 12+ months...
Tune will be with the low pressure actuator for about 14psi, then after track day, LQ9's will be going in, 18 psi actuator fitted, and tuned for 20ish psi.
i've also been trying to find info and results of the EFR turbos and stubbed on this last year but haven't kept up to date so 46 pages later....
i've emailed full race regarding set up for my SR so supper keen to see how you go dave. reckon the experance you have will judge if i go ahead.. or go just for a GTX28 good luck
Tuned by Willall Racing today. So after a long year, I can finally report some results.
Mainline dyno.
BC 262 cams. (I think they may be larger, it sounds real angry at idle).
140-145 compression across the board.
E85 with SARD 850cc injectors.
Blitz SBC-S boost controller.
Custom made thick walled S/S manifold.
And finally, there's an air leak somewhere. Inlet manifold I think, gets up to 17psi nice and quick, drops to 15psi, and holds. Probably a handful of KW to be liberated there.
Anyway, results,
261 @ 17psi (bleeding off to 15). Full boost somewhere around the 3,400rpm mark. It always wants to get onto boost, cruising at 90km/h in 5th gear and you just have to breath on the pedal and it comes onto boost. Comes on nice and strong, but even with my dodgy 11 o'clock at night eye alignment, it's very controllable. And yet, it'll quite happily chalk 255's in 3rd.
And it sounds f**king brilliant.
Gonna get it smoke tested if I can find someone that does it, seal up that leak, and put it back on the dyno.
I've asked the tuner (Donnon) to email the dyno sheet, so hopefully I'll be able to get that up in the coming days. :)
Mainline dyno.
Anyway, results,
Congratulations on the result, but the No.s seems low for what its got.
I have a Garrett GT2871 56T in .64 rear in my 180SX SR20det with Tomei Pon cams and that made 260rwkws on 18psi with pump 98 fuel. 261rwkws on E85 is propabably just pass 230rwkws on pump. Whats that turbo equivalent to in Garrett range?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
