correct - XS Engineering shut down many years ago. However, Blackmarket Racing aka 'BMR' is located directly behind Full-Race... and they bought the dynamic testing dyno from XS. BMR had wanted to get it from XS for many years becuase it has some special features (such as extremely accurate measurement of drivetrain losses) however when we dynoed the evo i accidentally brought up the old template with the xs logo.
edit: i know the chart says "engine" on the screen but I assure you this is whp. the point i was trying to make was that a turbo thats larger than gt35R is spooling like a gt30R... and making more than 35R power
Edited by Full-Race Geoff
Ah gotcha. That's very impressive!
As for cobraa's comment:
"My other comment would be great if you could make a complete kit instead of a kit that need more modification and fabrication"
That would be cool indeed but then the already "expensive kit" could go up another $500-1500 (depending if you meant intake pipes, filters and hoses/fittings)
And as full race has already said at some point, there are already plenty of good downpipea and what not out there so they focused on the required parts that weren't available, or something like that
  • Like 1
I got lazy right at the end and didn't mix up fuel with ethanol and got it tuned on 98RON despite having 9.5:1 compression ratio. It couldn't really take any decent timing numbers at all. Still makes full boost at around 3200 and makes 258rwkw. Dyno printout is at home so will upload a pic tonight. Printout is in km/h rather than rpm at the moment so just trying to decypher it at the moment. I reallyneed to put a softer wastegate spring in it and lower the boost a bit to get a bit more timing into it imo.
hey brad - did you post this dyno chart in the thread? I just looked for it but could not find it. Would love to see the torque curve, with full boost at 3200
The dyno run with a fairly quick ramp rate did not represent the on-road boost threshold. It showed full boost at around 3800 on the dyno.
I'm now running my E30 mix and have added 2psi of boost across the board and around 6 degrees more timing in most of the full load cells with no sign of knock. I didn't push it any further but I plan to get it in to the tuner in a month or so see if has any more headroom and get a good dyno printout with RPM and at a slow ramp rate.
Been waiting for this kind of thing to start filtering through - a twin scroll EFR9180 on a 2.2litre EVO X:
Mods:
2008 Evo X GSR
Fuel: 93 Octane + Meth
Mods: Moore Automotive Built 2.2L (Manley 94mm Stroker Kit with Turbo Tuff Rods and ACL Bearings)
AMS TMP Cams
Kelford Valve Springs
Ferrea Intake Valves
SuperTech Inconel Exhaust Valves
Cosworth 1.3mm HeadGasket
ARP 625+ Head Studs
JDL built T4 Twin-Scroll Turbo Manifold
Borg Warner EFR9180 (T4 TS) Turbo
Tial MV-S Wastegates (open dump)
Moore Automotive Custom 3.5" Turbo-back Exhaust and Dump Tubes
Moore Automotive 3.5" Intake, 2.5" UICP, 2.75" LICP
ETS 4" Intercooler
ID1300 Injectors
Walbro 400 Fuel Pump
Moore Automotive modified Fuel Pump Housing with -6AN outlet
-6AN Fuel Feed Line
AMS Fuel Rail
MAP FPR Kit with FuelLab Regulator
Snow Performance Direct Port Meth Injection Kit
Exedy Triple Disc Clutch
Jack's Built Transmission
STOCK Sleeves, Head, Intake Manifold, and Throttle Body
C_Hoover_Moore_Evo_X_GSR_22L_EFR9180_Dyn
Apparently was running out of fuel system - he reckons he needs to (and may?) upgrade the fuel system to get more out of it, definitely didn't reach the limit of the flow of the 9180. 25psi by just after 25psi for a 94lb/min turbo on a 2.2litre is offensively good. Its just dirty... basically this is better than PT6466 spool and better than PT6766 flow, for those who are obsessed with Precision turbos.
Guessing there is supporsed to be a rpm number here.
yea lith - this EvoX is the daily driver for the owner of MooreTuning. He started with EFR7670 1.05 a/r and then switched to the EFR9180 1.05 a/r. Really nice guys, I met them in the BorgWarner booth at PRI and spoken a few times over the last 4 years. Typically they sell a lot of precision and FP turbos so he was interested in the EFR but like everyone else was a little skeptical. now he has a decent opinion on them, keeps calling it magical :stupid:
  • Like 1
I like !
So can I/we expect the result on this 7670 to be better since we have 2.6 instead of 2.2. I know nothing about evos and don't know if they can compare, somehow, to rbs.
EVOs tend to drive turbos better cc for cc.... unfortunately
You can't beat a square engine :)
Hence why I would love to see a well equipped NEO dirty 30. I may just have to build one ;)
Also the 4B11T is a more modern engine than a 4G63T or an RB six . More modern head designs inc chamber and port cooling and variable cam timing both sides .
Brad I'd like to hear more about your E30 experiences maybe in one of the ethanol/E85 threads .
Cheers A .
Yes I like that idea too though engines like BDAs and FJ20s were a bit more than square . If Nissan really intended the RB30 to be a true high performance engine it could have used the bore and stroke of the VG30 which I think is 87 x 83 . Sadly V6s package better than straight ones so RBs died a quick death . BMW kept them alive for a time but eventually went to the dark side with a V8 I believe in M3s .
A .
How do you figure this? Many of the best performance engines are square, or very close to it. Check out SR20DET, K20A, 2JZGTE, 4G63 etc... I would take any of those over any of the options on the other list
  • Like 1
I've got a neo 30 on a slow build, which I'll probably go with the EFR 8374, won't be ready till next year though :(
  • Like 1
a larger displacement engine will usually spool faster. the 7670 is a great turbo, but a bit small for an RB26 if you plan to build it. The 8374 is a better match in my opinion. We have an rb25 pro drift competitor who runs the 7670 (because he wanted a bit quicker response for his small local track) but i expect he will have an 8374 on there soon for the big tracks:
what is a NEO dirty 30?
A .
adrian normally i agree with you, but you must be drinking tonite. :cheers: BMW produces far more turbocharged Inline motors than V motors...
An RB30DET sporting an R34 RB25DET NEO cylinder head.
You get improved combusion chamber and port design, along with VCT and solid lifters.
A pair of drop in cams will make for a formidable budget alternative to a high performance head.
Well Lith I guess it depends on your definition of best performance engines . Generally the highest horsepower comes at revs and under square engines often are not top end screamers .
The greatest limitation power wise for a square or under square engine is the lack of valve , mainly inlet , valve area . There comes a time when the cylinder bores limit valve size you can physically fit in the chambers . You mention SR20s and they are an interesting case in point . These were developed to be an east west as well as a north south engine so packaging compromises in east west form limited the blocks length as well as the bore centres . It was not really intended to be a competition engine even though Nissan had half a go with the Pulsar GTiR version , which ended up being an epic failure as a competition car - won jack shit . The only serious engine was the Super Tourer Primera one and it was so far removed from a production SR20 as to be unrecognisable . They basically had the 89 x 80 bore stroke of the FJ20 as well as turning the head around and then driving the cams from the opposite end . The block and head castings may have started out as SR20 but in the end there was SFA Nissan about it .
I'm not so sure Toyota went road racing with the 2JZGTE and even if you could stop the Supras body flex the manifolds are RS on 2Js .
The reason I mentioned the old Cosworth BDA was because it used a big bore compared to stroke bottom end and the head worked very well in its day . A real race twin cam head is quite tall because the included angle between the inlet and exhaust valves is narrow to keep the valves out of the pistons and also to house steeply downdraught inlet ports . A tall head needs a not too tall block to fit in a production car and that works out best with a big bore and a short stroke otherwise the complete engine gets too tall . Same story with Nissans Formula Pacific based LZ twin cam engines in the "L14" blocks . These were actually L18 blocks with short stroke cranks in them and hanging 10000 revs off them was nothing .
Off the top of my head there is no square RBs though 30s from memory are closest at 86 x 85 - from memory . They get a leg up from having quite long rods too .
Now to a theoretical RB30 based on VG30 dimensions . Larger bore could have supported larger valves and depending on rod length the block may not have needed to be as tall as an RB30 so a little easier to package in twin cam form . We'll never know .
The one non standard RB variant , RB24 , really shows the shortcomings of lack of bore diameter . Compared to an RB25 a 24 lacks valve and port area and there's SFA you can do about it . Compare the bores and strokes though neither is square .
4G63s are an old design now and in competition use (FIA Group A) they never busted 5500 revs with turbo restrictors on them . You can probably argue that a slightly undersquare engine may make slightly better torque (low to mid range) when it is rev limited - doesn't rev high enough for valve area to be a problem . Also rod and piston inertia not a real biggie provided they can withstand the high boost almost diesel like characteristics .
Sorry Geoff must have been thinking of the NA I6s .
Edited by discopotato03
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
