Just a few pics of a test fit. The 7076 is compared to t04z in first pics, I cant believe how big the thing is! I have some more machining to do on manifold then i have to re-fab my dump, make a new s/s intercooler pipe. Put the poncams in, somehow fit the p/s res in there somewhere as the comp cover sits where it did now! then make a oil drain. Im going to use hydraulic hose onto the jic fittings with some fire sleeve over it (unless this is bad idea?) then re fit everything I dont have to molester for this to work, and make an impossible heat shield. Should be fun!
Beautiful looking turbo, Why can't Garrett make Vband compressor housings... Have fun with the fabrication. Take your time to smooth out the flow path, I want to see best possible results out of this one. :)
I plan too! I have to doctor my manifold too. Its a greddy one and i'v never seen such a shit job. No internal fusion at all, bits on the inside of the collector are coming off. Really need to fix that just got to work out how.
Be careful... If bits of shite are de-materializing inside the manifold its only going to lead to a busted EFR and no warranty.
I'd be twice as careful with trying to weld it.. And I'd seriously consider parting ways.
Awesome, very much looking forward to seeing how this comes out - EFR7670 on an RB25 was something I fully intended on doing a couple of years ago, and been hoping someone else would do it. Good luck!
Its just a bit of weld material where someone has welded cracks before thats kinda ugly. I dont plan on welding internally but ill remove any sus looking metal before i fit it back up. Not sure that any would come free but ill tidy it anyway. When this one gets beyond it ill fab a replica one up in 3mm wall s/s. till then ill give it a tidy. Anyone want pics of ugly bit?
My favourite thing about EFR turbos is doing this (very, very quick clutch tap from 2500rpm):
https://www.youtube.com/watch?v=c9FWbtCK2HQ
That's 3rd gear up a hill. Waaaay too scared of breaking the gearbox to do it in 4th.
Edited by bradsm87
I don't mean to take away from all this big numbers talk, but what are peoples opinions/thoughts on a 6258 on a RB20? I'm currently running a 2530, would the 6258 be similar in response/spool?
an RB20 would absolutely rock with the EFR6258. it would feel like an rb26 with good turbos ha
  • Like 1
Don't take it as gospel, but I think 3rd is weaker than 4th in the SR boxes, due to the bearing locations? So it's not the best option, but hey, they going to break sometime!
  • Like 1
Hi Geoff, thanks for the reply. I sent [email protected] an email about purchasing a 6258 and manifold etc to suit, but have yet to recieve a reply. What would be the best way to go about it? Could you moddify the exhaust housing in house prior to shipping, and could you make an internal gate manifold in a t3 configuration to suit?
Thanks,
Tim.
sorry, we were away at SEMA. been getting caught up, Ill make sure you get a response on monday. In my opinion, the best way to use any of the EFR turbos is with a twinscroll manifold. The new "G housing" is 0.80 a/r twinscroll IWG B1 frame and available for 7163 first then 6758 and 6258. Of course if youre on a tight budget and wanted to use an off-the-shelf manifold, either t25 or t3 adaptors/flanges could be used or welded on to either side to make it all work
No worries. Interesting. So does the 'G' housing come in a t4 configuration? If so it could be matted to one of your 'off the shelf' twin scroll IWG manifolds?
Is there much difference in a .64 open and a.80 TS?
Hmmm im really liking the idea of an EFR on my evo 9. Kits are priced damn good compared to bolt on turbos too! :D What would you recommend for 300+kw with the best possible response Geoff?
I like this kit but is it possible to use a 7064 instead of the 7670 as my car is stock block 2L?
http://www.full-race.com/store/efr-turbo-kit/mitsubishi-evo-4-9-4g63-top-mount-iwg-efr-twin-scroll-turbo-kit-1.html
Edited by Mick_o
This is a link to a Ford F150 site and Geoff pops up because of the turbo kit Full Race has been developing for the 6000 lb 3.5 litre V6 powered truck . http://www.f150forum.com/f70/definitive-full-race-motorsports-eco-boost-thread-208585/index8/
Page 8 has a pic of BWs mixed flow turbine unique to their EFR 7163 turbocharger . Its interesting to see a different perspective to forced induction particularly regarding the 7163 .
Earlier I found a thread on the Mazdaspeed site that had the comp map of the 7163 , interesting if you haven't seen it , very wide so a wide ranging unit overall .
I'll see if I can find the link , cheers A .
Here it is about half way down . http://www.mazdaspeedforums.org/forum/f424/game-changer-efr-7163-a-159047/
Note the first post where the OP reckons according to Garrett the Indy EFRs don't use the lightweight turbines ?
I'm not sure if a 7064 tops out higher than a final spec 7163 , bigger housings ?
Whatever 60 lb/600 Hp potential is right up there for the frame size . Honeywell must be wondering what to do when this turbo arrives in volume , the OE market would be watching too .
A .
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
    • 300kW is so boring in a Skyline, you'll get spanked by someone's mum's Golf with Alibaba pipes, and an email tune.
