Here is a 6266 on a 2.6 on what I assume is the same dyno. Notice it goes to 210km/h so scaling is different.
Assuming 8k limit, @135km/h its on full song at about 5200.
Edited by burn4005
True ebough, if its 7.5 its more like 5k.
I'd be interested to hear what the scaling actually is. I've always liked the efr83s as my next turbo, so if he's let off at 7.5k ish and making that power on a 2.6 I'll be extremely impressed with it.
As with most things I don't think the dyno plot can explain the response of it, but I'm betting its miles better than dash 5s at circa 2 bar. The efr looks like it comes on very smoothly.
Edited by burn4005
Going off what Brett has said. 22 psi was reached at 4300 RPM which on that graph is 105 km/h. It's making just on 300 kW at that point.
Posting on behalf of "Reaper".
Stock N1 engine (V spec II nur)
Borgwarner EFR 8374 1.05 AR rear
AI industries surge tank and Holley 1800 dominator pump with Walbro E85 intank pump
Bosch 2200cc injectors
Tial 44mm wastegates
Full Race twin scroll
4" dump into 3.5" kakimoto exhaust
ATS carbon twin clutch
HKS 100mm intercooler
HKS Step 1 V cam (248 @ 8.6mm)
AAF5E4D7-F072-4218-B83D-7D64932E8EAD_zps
Jezzebelle stopped there because of the standard engine.
* Green line is as it was dropped off, Red line was the final result.
stock longblock, small cams and simple setup! this car is probably much more fun than a dynosheet can explain, hopefully Reaper is pleased with the outcome
  • Like 1
2jz with twin 6258s -- slightly OT, but too cool not to share:
"Geoff, wanted to keep you in the loop. Re dyno'd the twin 6258 IWG car on E85. Got her to 32-33 psi and ended up with 922 whp and 790 tq at 4600 rpm !! This is a 8.5-1 engine with a stock head and 264 stock base circle cams. Wowzer…I attached the dyno chart with the C16 vs E85 max effort pulls.. So impressed really. Cant wait to fire my car up with 7163’s…Thank you
Eric"
Edited by Full-Race Geoff
  • Like 1
at 4k $ the v-cam are far from ''small simple cams '' IMO :)
Edited by cobrAA
Its a type a vcam intake with a type b poncam exhaust so they are pretty small especially considering no porting or anything at all.
  • Like 1
5th gear, 285/30/18 rsr's and standard 34 gtr diff ratios with the standard 6 speed
Can't have been 5th gear.
5th @8000rpm is 220. top of 4th is 168km/h. which matches plot exactly.
so full boost@115km/h is 5475rpm.
300kw @ 5000rpm
400kw @ 6000rpm
***ignore above.. bad maths***
Edited by burn4005
whoops! they are, good pickup.. sorry i under calculated the tyre circumference.
using circumference 1973.55mm (https://www.mcgrefer.com/sizeinfo/2853018) for a 285/30/R18
speed peak of dyno of 169km/h in each gear:
3rd (1,685): 8500rpm.
4th: (1,312) 6650rpm
5th: (1.000) 5050rpm
it appears it was done in 3rd.. could an 8500rpm readline be correct?
that means spooling (10psi) around 4500 and full boost (27psi) at 5800rpm
Edited by burn4005
No.
BDD1D388-D7FB-4173-A70D-1D94542F4DDE_zps
There is a graph from very early on in the tuning process. 10 psi at 4500?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
