Those exhaust versus intake manifold pressure levels are pretty unacceptable imho. You'll find at that kind of level your engine VE will be plummeting compared to normal, if it's even sustainable My take away from that is the 7670 is a terrible call for that engine setup - at least at those rpm.
Nismo32ish - because the way the thread convo has panned out I feel compelled to point out that these theoretical numbers AREN'T for E70 like the earlier discussion could lead one to think.
Would the 8374 had been a better choice for my 3.2 build for response , I was looking at the 8374 when I was sourcing parts but was recommended to get the 6262, that turned out to be a 6266. Just wondering, Paul is being a pest,lol
I'd have gone an EFR8374 over a Precision 6266 on your car with what you were after, money being no object. I'm certain it'd be a nicer setup - though I'm not really so sure it'd be worth the money and effort changing now that you have the 6266 - though. Depends on if you still feel it needs more snap? Maybe try and find someone with an EFR on board?
Edited by Lithium
See what I mean about a pest :)
When I said OK to the 6262 it was going on the 2.6 as luck had it they put the 6266 on ?? so I thought I would leave it on and see how it goes with the 3.2 and it is pretty good but the 8374 seems to get going a bit earlier and I would like a bit more snap but happy with the way it goes.
If I ever decided to change the 6266 to a 8374, is there much extra work to fit it on the setup I have now?
Dump pipe won't line up and a slight pipe mod to the pipe that runs from the turbo outlet to the guard.
This is your fault, making me think about another stupid Turbo that probably not worth the exchange for the extra go ?
Hard to find out much about the 2 but there does not seem to be much in it, the 8374 seems to spool a little earlier, but very little from what I could see, but ??
The PT6266 CEA is Gen 2
Edited by Nismo 3.2ish
For what it's worth Pete, just leave it alone and drive it. Honestly.
  • Like 1
This is exactly right. That 6266 makes serious top end (I would think compares better to the air works 8376 s300sxe I posted). Only problem is there isn't s lick of data on precision turbos and I'm a mechanical engineer. I like designing before I commit my money!
Totally true!
Didn't want to make TOO many changes. This would be closer to racegas.
FYI I've started working on timing. WOW...BIG changes!
Be prepared for new dyno numbers! Haltech is super conservative! This car just picked up a definite seat of the pants increase at only 2 deg advance...and NO KNOCK.
EDIT - just reviewed log and Fuel pressure is dropping off on top end. I'm betting I've maxed the DW300 pump. It hung in there pretty well...any clue on what -6 AN lines and stock fuel lines will do? Am I limited there as well while I'm making changes?
  • Like 1
I have the Haltech 2500 Elite ECU, having some spiking problems. Went back and had a tune touch up and seemed to fix it but the weather went cold and I am having the same problem @ 4000rpm + after it is on full boost. It spikes and the ECU makes it drop back for a split second and off it goes again. Just needs a touch up again to sort it out , but I was wondering, the HKS evc 6 boost controller was taken off and then the ECU was running the show,
Would the same spiking situation be happening if the HKS boost controller was controlling the boost, I am not changing anything, just wondering ?
ECU should do a better job than the evc. Extreme temperature swings will challenge any system at full boost. Mention it next time you are in the shop but I wouldn't think it justifies a special trip.
This was explained and I do understand.
Just wondering, the adjustments had been made to the tune on a cold day and it was great for a couple of weeks, then the weather started turning cold up here when it started happening again. I usually go early in the morning, at the coldest time of the day, so I waited until 2pm when it was much warmer and ran it again, same thing happens.
This only happens on E85 and it makes 75KW more than 98 pump @ around 4000rpm , could this cause the spike as it wants to keep boosting and the ECU steps in and stops it and brings it back to where the boost should be..
I am not worried, I am with a great shop that looks after their customers, just good to get feedback from blokes that know what they are talking about and you may find it interesting or have had the same experience :/
lower the base duty and let the closed loop do the rest
He is trying to hold the wastegate shut as long as he can to build the boost faster, looks like it has to be less aggressive for the colder weather , boohoo .
Add a trim knob. Not sure how it works on those models but in closed loop on platinum the trim knob can lower the target boost (and resultant tables). In open loop it drops duty cycle by a certain percent.
How much spike
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
    • Off the back of feedback we have decided to mix up this next Motorkhana at Avalon to have some targeted skills practice for beginners to advanced. Saturday 6th September 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Friday 5th February  Where: 55 beach road Avalon. https://maps.app.goo.gl/HNUE3EuNue3sJxh38 Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and a 1KG mounted fire extinguisher recommended (But not Mandatory). Further details within Supp Regs on the enty link. Entry Link > https://www.sauvic.com.au/entry/deca/20250906 You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List:
    • Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
