I'm also on the internal map sensor so that's why I don't like to run more than 20 at the moment I don't mind a little 2 pound spike over but I'll only hold it at 20psi at this stage.
every load cell has been tuned except for the impossible areas which never get seen in reality.
but while you have those recorded logs on the haltech it's a good time to go and address those load cells at 1000 RPM and up while you have the logs available I'll ask you are you running closed loop o2 control.?
for myself Im only using it for vacuum areas as soon as mine sees 0 PSI I switch to open loop and run off the map directly.
How you have yours configured makes a big difference on whether you can make those fine adjustments based off logs that's all
[emoji111]
  • Like 1
2 minutes ago, mr skidz said:
I'm also on the internal map sensor so that's why I don't like to run more than 20 at the moment I don't mind a little to pound spike over but I'll only hold it at 20psi at this stage. I'm at my car pretty anally so every load cell has been hit except for the impossible areas which never get seen in reality but while you have those recorded logs on the hell tech it's a good time to go in a dress those load cells at 1000 RPM while you have the logs available I'll ask you are you running closed loop au to control for myself I'm only using it or vacuum areas and like cruise soon as my a 0 PSI is detected I switch to open loop and run off the map directly.
How are you have yours configured makes a big difference on whether you can make those fine adjustments based off logs that's all
switching sounds like a good idea. I actually had pretty good results from open loop at first, but now I'm running full closed loop. It is a little frustrating in that you can get it perfect for fast shifting then it's weak on the low ramp or vice versa. The alternator voltage seems to have helped my fuel pump keep up with power (an issue I've been having), so I was afraid to try much leaning or boost until I get that sorted.You can see my request and actual outputs in that log (I think I have everything checked).
Keen (as you guys say) to see your results.
11 minutes ago, acsplit said:
Meanwhile I am very happy with my -5 3ltr setup and would not change it.
Now I am unsubscribing from this thread because of too many useless posts! :D
It sounds like it would be a great combo. Enjoy it. This thread is far too old and far too diluted to complain about, but I am trying to still provide what data I can to help those make an educated decision.
  • Like 2
56 minutes ago, mr skidz said:
That would be a torque monster!
Yep it is, pulls stumps good!
Ask Paul or Steve-o and that was before it made 370 rwkw @17psi on 98.
*I have now changed notifications to a weekly digest :) back to the EFR talk.
  • Like 3
Where have people sourced the correct Vband and clamp for the 8374/9180 compressor housings?
Treadstoneperformance (TRE) you can weld 3" on the inside of theirs and 3.5" on the outside.
3" assembly:
http://www.treadstoneperformance.com/product.phtml?p=68259&cat_key=613&prodname=Borg+Warner+EFR+Turbine+Housing+V+Band+Clamp
Both 3 and 3.5" flange:
http://www.treadstoneperformance.com/product.phtml?p=2542&prodname=Borg+Warner+EFR+Turbine+Housing+V+Band+Flange+3.5%22+Downpipe
I would not waste my time going 3" again
Nicks car just in.
-5's 424 rwkw at 24 psi
8374 1.05 462 awkw at 24 psi.
Same setup, same engine. 3.0, 9.0:1 comp, 260 poncams. No graph yet.
We don't care about peak power, how does it drive?
  • Like 1
Yeah that is not my RB30.
SR20DET built motor stock head.
EFR 7163. There is a lot of history in this car, I will update more when the owner gives it the nod. Should be tuned next week
Yes please. I have the TS 7163 IWG on SR20. Interested in others results.
Cheers
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
