Is there any likelyhood the EFR9180 will be replaced and tried out or has that been abandoned now that the old faithful Garrett based unit saved the day?
bloody oath mate. as soon as possible there will be a EFR9180 back on the Advan/Hi-Octane/RGM R34. Mark it about to try some other stuff (not turbo related) but as soon as we get another 9180 it's going back on for more testing. and we were all so happy with it's initial performance we are converting the RGM R32 to a full race manifold, twin turbosmart gates and a 9180 too.
the T04Z was ok but it was only ever 'plan C' and a last minute back-up option. it was used simply because Mark had it available (was on the R33), and would fit the existing full race manifold set-up most easily of the available options (2 days before the event we didn't have many other choices!).
It's full steam ahead with Full Race and Borg Warner EFR gear on both the RGM GTRs.
Awesome, looking forward to hearing how they both go - whenever the new units become available!
Mr Sub - ahh blargh, the nature of my work means that if I post during the day sometimes I engage autism mode. My bad :whistling:
Will the R32 still be a 2.6?
yes it will. :) there has been some serious heated debate over this one and to be honest (just don't tell anyone I said so) I can agree the logical/smart choice is to go 3L so it's the same as the R34 but the 2.6 option has some merit too and it's the way it's going.
as far as ancillaries etc go both cars will be almost identical though.
Tiny bit more progress.
Looking rather comfortable;
Had to clearance the mounting plate for the BCSV (which I won't be using...) slightly because it comes too close to the manifold.
And the banjo fitting solution for my water lines... Not so good.
Hard to see, but the outer edge and bolt for the recirc valve cover still hit the banjo bolt. Gonna head down to Pirtek and Enzed whenever I've got time and see if they can do anything for me. If I can't find a solution, it is safe to run these as oil cooled only... But I'd rather keep water cooling.
Only need to clock it a tiny bit more...
Plan was to have the outlet pointing straight down to avoid the water fitting problem and allow me to run the Pierburg, but there's the lines for the A/C and an engine mount in the way. It'll also require a pretty hard bend.
Probably largely irrelevant on a forum dominated by RB's, but you get that.
So what would one of the 6258 in single form be like on a 2L?
Ive read in a couple of places that an RB20 has similar character to an SR20, you may want to watch this thread to find out.
Correct me if Im wrong but it had been said in this thread that the 6258 is the turbo to have on an SR.
Based on what ive seen on a couple of other forums (cobalt and astra) I would probably be willing to go the 6758, there are also videos of a civic on youtube which absolutely hauls with one. The problem with all of those are that they are modern hicomp motors.. Kind of like the talk we had about VQ heads vs RB and the ridiculous flow differences.
Im still up in the air about new tech/old tech stuff... There is a good chance your better off leaving a TD on your ride :P But that civic on youtube is insane.. Instant gutfull of torque and delivery that doesnt just fry the tyres, MMMMMMM
Links? :)
No small pot-6 RB20 I've seen has turned a turbo as good as a big pot-4 SR20.
Would be interesting to see either way.
Not for the RB20, its'sorted and not touching it. But looking for a turbo for the 2L 4 in my Cossie as it rocks old school lag and as its a daily would be happy to lose some hp fof drivability. Runs a twin scroll manifold std, though not sure but think its T3.
Would having a small, say, 1/2 to one inch spacer made between the manifold and turbo housing help your clearance issue?
The EFR6258 and EFR6758 are T25 flange, or would you make up a manifold for it?
lithium, one benefit of the stainless steel housing is that it's a real pleasure to weld to.. if you wanted to run a t25 efr on a t3 manifold, properly weld a t3 flange on and port to suit
Edited by Full-Race Geoff
Guest
    • Ha ha ha, that's fair mate! We have the crackhead dogs now. Mainly because the missus wants the crazy dogs while she still has the energy and capacity to be able to keep up with them! Ha ha our current two are both Working GSD, there brothers and sisters (from the same litters) are in Police, Corrective Services, and I believe one did end up in defence force too. They're wild and fun, yet right now, both curled up asleep on the lounge room floor while we watch some TV. Mal is very likely the next dog (unless I get my couch potato guardian dog 😛 )   What are your Kitties names? Are you planning some house work, like those high kitty shelves, built in scratching post, and some cat passages from one room to another room?
    • Maine Coone, did look at but to big and fluffy As for performance dogs, we had Mals at work, performance dogs are fun to watch, but, way to much work for this old rooster
    • Yep, it was only an option on the Q50 Hybrid.  Same in Japan as far as I know. And doesn't use a centre diff like the Suby's do, so not the same as the WRX.  But it also isn't a reactive AWD like other Nissan AWD vehicles are, eg. Murano/Xtrail/etc.
    • You should have got a Maine Coone then. Only thing is they're big. But so cool, and just like a dog. Or, just get yourself a high performance dog. That'll teach you for wanting Parkour indoors 😛
    • Are you thinking of Bens R32? I don't remember if his went through the bonnet itself, but it went through the chassis rail. Brad (RISKIN) bought it, and turned it into a track car. It's funny how anti people are of Jim Berry now. I remember when I pulled mine out (during an engine change) and inspected it and found it cracking badly. At that point in time so many people were even on SAU, were so pro Jim Berry, and that was after Bens GTR exploded his quite publically.
