Nice choice. The factory Aero is definitely nicer than the standard RS "smile".
All you will need to do is pick up some black mesh from Autobarn (about $30), really finishes it off nicely.
Edited by iamhe77
I hacked into the trans ecu and cut the yellow wire controlling the Tourque converter solenoid, placed a resistor across the ecu output to trick it into thinking there is a solenoid there and ran 12 volts straight to the TCC solenoid. Now I have a switch beside the shifter to lock up the tourque converter while driving. (just a temp solution as the trans ecu gives a gentle ramped voltage and I need a firm engagement.)
Im also putting a kit in the GTR callipers I have, definitely need those brakes done...
Nice choice on the bar, do you have the foggies to go in?
agree, black mesh going in :D now i need the other aero bits or else a nice alternative rear and sides...
I don't. I have been struggling to figure out what to put in. The factory one's are round but I've been toying with putting in square one's. The mount is quite square. There's also a nice (round) set of projectors one's I've seen and a light strip of LED's like on the audi's which might look good too. The spotties on one of the Lexus sedans look nice too, sort of oval shaped.
Can't decide dammit.
The sides would make great air ducts or allow a long intercooler. The fog lights get in the way of the 3 inch cooler piping I put in too.
Audi style lights could look good. Might be too low there though.
Fitted my 4 pots upfront with braided lines, Fitted my 3" downpipe and new track rod ends all on and tracked up.
Next, Move the bloody amps and wiring and secure them, I'm sick of them moving around when i go around corners.
What Have You Done To Your Stagea Today?
Well today I think I finally shagged 2nd gear trying to get a decent stading 1/4 time.
So now looking for some uprated internals ( and a bank manager that understands nissans)
6 speed r34 getrag with an ikeya formula shifter? :cheers:
mods on mine, 6" alpine type r coaxials for the rear doors (fronts already had some kind of focal splits in there), machined the rotors, jjr 40mm alloy core radiator to keep things cool
service coming up next week, Gulf Western S6000 Sougi Class 5 Fully Synthetic going in ;) (same spec as motul 300v chrono but only $68 for 5 litres) should be good, will be interested how it goes
TODAY I replaced a dead coilpack
Superspark sent me a new one for the price of 'on the house' since old number 5 didnt want to play the game anymore.
Took it for a drive for the first time in a week and she's excellent
Tring to buy a R32 GTR RB26 front cut, only probably is tring to find somewhere to store it for a month or 2 without the wife finding out!!!
Any idea's
Also bought some fancy brake fluid
i'll look after it for you :)
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
