Tring to buy a R32 GTR RB26 front cut, only probably is tring to find somewhere to store it for a month or 2 without the wife finding out!!!
Any idea's
If my car doesn't sell soon i'll sell ya the 26 from mine with the loom to go straight into your stag.
Any idea's
Also bought some fancy brake fluid
Send wife? PO Box 2161 Boulder WA :) Or has this already been suggested? Sorry, haven't read whole thread.
OK.....I'll bite.
Cooling
HDI FMIC
Phenolic runner spacer
Nismo low temp thermostat
Custom(fisher) 3" intake
V35 manual radiator
Twin Trans coolers
TB spacer(lol)
Powerduct( :D )
catch can(s)
Turbo
High flow original to GT30/71
HDI EBC
Handling
Bilstein shocks
Eibach springs
324mm DBA rotor
R32GTR callipers with brackets
Hawk pads cut to size
Body
19" Lenso rims
R33 GTR N1 scoops
fully sic Nismo strips(custom fading ;) )
eyelids
Exhaust
Dump pipe....some japanese one
Complete Exhaust from Charlstone
ECU
Haltech platinum interceptor.....soon to go for a replacement reflashed ECU
Interior
Twin headrest DVD players
DTV
English conversion
On the horizon
Sway bars
Custom Airbox Suction pipe setup
Brembo's
Paddleshift's
Gearbox rebuild with stage 2 shift, 3,500 stall(depends on reflash outcome) and MVB
Bonnet pin's so I can lock the bonnet closed and give the key to my wife to STOP ME!!!!!!!!!
Edited by Jetwreck
I put the new cover on the motor, just got it back from the powder coaters.
unfortuntely at the same time I found the old cam breather hose had a split so it has a temporary blue replacement.
That looks awesome
That looks awesome
I'm guessing you don't mean the crappy blue breather!
Great work again from Craved Coatings on the cover... I picked up the cover on SAU, it was hand sprayed from a can. Craved sand blasted then powder coated in in crinkle finish black - looks mint :P
I was gonna ask where you got that coilpack cover from, Duncan - good find!
And yeah, Chris @ Craved Coatings is doing some awesome work, and he's definitely putting the hard yards in! I think he sleeps (much) less than I do!
I finally got rid of the stock exhaust, to replace it with a 3" X-Force stainless steel system, with a new dump pipe and 3" high flow cat con.
The guys at C-Red even gave me a silencer with it if the neighbors complain ^_^. Idont know why i didnt do it sooner! ^_^
That black bit on the cam cover is dear as poison. Just got one from Nissan. Nearly $40.
Luv that cover.
Edited by 66yostagea
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
    • Welcome Adam. Car looks great!
    • "With a 1.5-WAY, the LSD is effective only during acceleration."
    • Well it wasn't as easy as I thought.... and it also wasn't in my original manual which I did end up finding. They discuss the process in the Nismo catalogue though and it requires slight machining. Page 145.  NISMO PARTS CATALOGUE 2020
    • I'm an idiot, my intercooler is rated for 1000hp. I had clicked on the wrong product. Knowing the delta P would be nice, but I'm doubtful I'll do it. Now as for an EMAP, that would be great and I'll get around to it eventually but from my findings in my last post, I'm considering a turbo swap now.
