just washed mine after a run up the mountain on wednesday (was fithly after it)
got a hose onto it and gave the underside a good spray
i cant belive how much mud/dirt/rocks there were stuck under the side skirts and hiding away in the rear bumper
i reckon about 20kg of dirt came off the underside and i dont think it was all from that one trip
Well picked up my first stag yesterday 97 model and has 25t xfour written on the back got cream leather interior the satelite navigation tv screen in it has a full 3.5 inch TBE and hks turbo timer also has 18inch rims look like volks of some sort but gotta pull them off and have a look and the best part is I picked it up
for two grand with 8 month rego any how will be going in next week to have a new crossmember put in as the one in it is twisted and also will be getting a FMIC and injectors and eboost 2 put in and then have a tune done so will let you know how it all goes.
Patrick
nice 1.
finished with the stagea for now. last mod was the r32 gtr front calipers. 249rwkw.
working on doing up a r32 4door gtst sedan, with r30 manual & rb26dett engine.
excited. boat finally brought my container.
tomorrow get to p/up stich mags ($30 pound!).... these will hopefully fit the stagea
grex camshafts, spats strut bar, 6-point roll cage
exhaust temp sensor, turbo timer, bride left hand seat rail
bride drivers chair, apexi power intake piping kit
got all the parts for the rb26 buildup in the cupboard now:
hks oil pump, hks step 2 cam springs, n1 water pump, acl race bearings
hks 87mm pistons, attkd rods, arp bolts, arp main head studs
cometic street pro full gasket kit incl 87mm mls head gasket
tomei sump baffle pickup kit, tomei oil gallery orifice, ati harmonic balancer
greddy timing belt, new idler/tensioner, adjustable intake/exhaust cam pulleys
30-row engine oil cooler, oil filter relocation kit, turbo oil cooler
hks split dump pipes, obx tuned-length manifolds, obx front pipe system, decat flex pipe
fitted wilwood superlite forged 4-piston calipers with 324mm drilled rotors up front.
got to install the external fuel pump and fuel surge tank system, then attack the exhaust
and sort out the seats, weld in roll cage and add to it, fill the belt/seat mounts in (eventually rego for 2seater?)
I changed the timing belt and caused the check engine light to come on.... :D
^^^ oh........pull the globe it will be fine!!! lol
speaking of pulling globes... kidafa not that long ago changed his dash to blue LED's... and didnt put his petrol light globe in properly...
needless to say he got a rather decent mileage to that tank...:D:D
Yesterday:
Hacked up the CF-look centre console plastic to graft an R34 manual shift console onto. But 50% done. All cutting/trimming is done, now I just need to plastic weld it all together and bog up the gaps. Later it all gets covered with some real CF. :bunny: Should be finished by early June.
Touched up/puttied and resprayed my front Aero type M bar.
While I had the bar off, refitted the electric fan in front of the a/c condenser.
Had to remove the FMIC to refit the fan, so I also discovered a 10mm size hole in the intercooler, from a bolt on the chassis rubbing thru. :thumbsup: Fixed it up, refitted and test drove it after. Bit more responsive now :banana:
In the next fortnight, I'll be upgrading my brakes to a 325mm kit. :banana:
    • Good tips, will get on those tomorrow. When doing the maintenance I did move a few of those connectors around, and things that are old tend to not like moving around. (Like me).
    • Don't try it. It will be shit. Better chance of damaging the engine than gaining any knowledge about the old one. Maybe, but unlikely, especially if the O2 sensor is working. You can use NissDataScan to look at the stock ECU.   Cleaning the AFM is seldom necessary and seldom helps. The R35 coil & loom conversion should eliminate dud coils or plugs. But as you still have misses - look to the plug where the coil loom connects to the engine loom, and the CAS plug. Need quality connections there. Also look to injector plugs. And the AFM plug while you're at it. Also look to whether your injectors are clean and flowing evenly. Get them out and onto a testbench.
    • Good to know, I feel like I am in for a rollercoaster ride that looks like a sine wave.
    • You'll fit right in. Acceptance is the first step.
    • Hey folks. I've been lurking and browsing the forum for a while, since I got into my head that I wanted a skyline. Having purchased an overpriced completely stock GTT, (only "mods" it has is HKS pod filter and catback) now that it became legal in the US, it was all glorious and sututu noises here and there. But then I wanted to do things right and went to do basic maintenance. After all the fluids, filters done, I did the spark plugs, that's when the problems started.. First the car started spluttering at around 4.5k RPM. Which I gapped down the new plugs and that solved the sputter there, but the car now always misfires at idle with pops when lifting off and shifting 2nd to 3rd. Similar to the issues in this recent thread. I've been banging my head against the wall, reading the threads here and trying suggestions for a couple months now, so decided to start this one to explain exactly what I tried and what is going on. The symptoms of the issue: Idle and low revs misfiring intermittently. You can hear the exhaust tone change and the shakes on the shifter knob. It happens frequently, but doesn't seem to have a rhythm to it. Pops when backing off throttle. It pops and or burbles almost feels like it spits fire when it pops. (Happens mostly in 3rd gear at around 2k RPM). When under load and after 6k RPM, it also pops when shifting from 2nd to 3rd. There's a ticking noise at around 2k RPM in 2nd gear going downhill, seems unrelated though but I am out of educated and downright dumb guesses. Not noticeable lack of power when putting the car into load. The attempted diagnosis and solutions: Unplugging coils when the car is running This did nothing to change the idling and tone shift for every cylinder. Checking the exhaust headers with thermometer They all are within what I'd say it is margin of error of the laser thermometer New spark plugs Tossed two new sets, copper, iridium and using the old ones, still misfiring, even re gapped to 0.8mm, still same thing. MAF cleaned with the "specific" spray cleaner No changes in the issues what so ever. Brand new loom and r35 coil conversion (was going to add the r35 coils anyway) car runs arguably better, still misfires, but seems like does less frequently. Placebo? Code 21 now being thrown, thanks nissan gods. Removed the CAS to check the shaft for play or anything. CAS seems all fine, nothing that indicates any issue, visually speaking. Things to attempted next: Ordered a new MAF (chinesium from Amazon, to be able to return regardless of result). Fuel with proper gas, maybe it is this California water that they sell as gas that is to blame? Plugin the link ECU and check the info using the built in base map. Go back to BMW and eat my rob bearing breakfast without milky oil mixture.   Do any of you have experienced anything like this or have any suggestion?
