Lost half my passenger weather strip last week on the way to ballarat
so I pulled the rest of it off as well as the drivers side strip
Christ it's a mess of tape and glue under there tho
any advice on the best way to get all the shit off?
Also hopefully getting flywheel Sunday
next week it's on!
5speed
fark yeah!!!
Put my ARC FMIC in tonight, need to make up some brackets for a more secured mounting. At the moment it will be held in position by the reo bar. Tomorrow I will cut the reo bar to fit around the FMIC & finish it up. Pics to follow.
Took the front off my car to get to the headlights & fog lights. I did try to get the foggies out without doing so, but it was impossible to get the drivers side one due to it being wedged against the reservoir for the windshield sprayer (I think). Shouldve taken it off to begin with, was ridiculously easy to get it out!
Hey Duncan, is that the stock m35 intercooler setup?
I was just thinking to myself, good placement Nissan.
If I was going to get an aftermarket unit, I certainly wouldnt get somthing that small! So yep, completely stock as far as the IC is concerned.
cheers.
something like this pic looks like it would suit the m35, even considering it myself.
And keeping back on topic :D, found this little neon floating around in the parts bin so though why not put it in.
cheers.
Looks a bit like the otomoto intercooler. I'm looking at one of these myself, could be a perfect fit below the bumper reo.
Opposite to above lol...
Changed from my Nismo LMX5's back to the stock, offset-fail 17" RS rims due to excessive brake dust from the 2 month old QFM A1RM pads (What happened? Why so dusty?).
Definite camber wear on the rear tyres but the fronts still have about 95% tread after 60,000kms !!!!!
if you don't get lots of heat into the ar1m's they are dusty and chew up the rotors a bit
the hpx are supposed to be better on the street - better performance than bendix ultimates and very little dust (the dust is a light colour apparently, not black)
so either brake harder or get some hpx's instead
LOL.
Yeah, I have the HPX pads on my wife's car. Pretty good and no noticeable dust, may have to go with them next time.
The Apexi ECU Harness arrived today, so I will have to get onto the install Sunday, I'm back at work so cbf after work.
Pics of my FMIC install as promised, did it Sat nite/Sun morning.
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
