Mazda 323 FTW. Mine is doing its daily duties great. Cheap on fuel, service costs pretty much nothing, as everything is shared with a Lazer.
Its like a up market corolla!
+1 for the 323 :thumbsup:
Our current one has now done 145 000km, and I've only had to replace a regulator mechanism in the drivers door. $120 and in stock today. Parts are cheap as and it does 6.5 L/100km rain, hail & shine.
Eunos? That 2 door thing? Or was there anbother one as well.
You want a granny spec 323- rear blinds and wool seat covers, steel wheels.
Then a 1/2 cut Famila GTR motor and box- forget the rear wheel drive, just run the front- that'd be a sleeper.
There was 323 in the mid 90's that had a 2L v6 in it, would be a cheap reliable daily, looked at one as a first car on my p's
yeah a eunos 30X, i dunno if the engine was any good, but they looked half ok
Same 2.5 litre V6 as the 626, beautiful engine, but when they go wrong; and they do... BIIIG dollars.
It came in the Eunos (as a 1.8 litre V6) or as a Mazda 323 Astina hard-top (4-door sedan) as well as Astina hatch.
Yep, same block, but the 323s were a 2.0 litre and Eunos was a 1.8 litre, (co-developed with Suzuki, I believe, and used in V6 Vitaras from that era and plenty of years after). Was a beautifully smooth engine. A mate had a 626 with the 2.5 and put an exhaust on it, and it sounded lush! I'm guessing the 2.0 would be just as nice to listen to.
Has anyone seen the movie "RED" with Bruce Willis, Helen Mirren, Morgan Freeman and John Malkovich in it? I was watching that and noticed that Jetwreck has a doppelganger in one of the other major roles...
http://www.imdb.com/media/rm2658108928/tt1245526
http://www.imdb.com/media/rm2356119040/tt1245526
http://www.imdb.com/media/rm1539997696/tt1245526
http://www.imdb.com/media/rm2815066112/tt1245526
Thought the same thing... he just needs more facial hair.
Pretty shit acting though
