Hmm...got banned from a Veloster Turbo forum for being a "troll"...apparently if I shatter their dreams and tell them that their tuned 160kw atw cars will not beat a Commo VF SS its "trolling"...ignorance is bliss I guess.
  • Like 2
Guy's just a random question - I'm wandering out of interest how much were the stags when originally released(in AU$ Roughly). I've got an S2 1999 WGNC34.
Edited by sekay1994
A 25t RS Four V was 3.26M Yen when sold new, so probably around the $40K Aus mark in '99. Chepaer than a VTII Commodore SS.
Edited by Hertz Donut
  • 2 years later...
The only cure for that is to buy another one and do all those things to it that you said you'd do differently if you had your time over again.
/experience
ha!
my S1 C34 was 255kw low boost ;)
did everything I wanted.
Ha, if I did it again I'd grab a 26tt Autech and adapt an auto ;)
Studies finished a few weeks ago, started a casual job but am actually in line to get a great gig as a cardiac & vascular radiographer, ie specialize in Angiography
Been getting by under the radar, only ever a few $ away from living under a bridge, so hopefully a new start on the horizon....
  • Like 3
Good for you mate; glad to see the hard graft is paying off for you. :thumbsup:
  • 3 weeks later...
  • 2 months later...
I didn't know whether to post this here or in 'What Did You Do To Your Stagea Today?' But here goes...
Today I dropped an unwrapped Mars Bar on the floor while I was reaching for a slice of pizza from the box on the passenger's seat, and it went right under the seat.
Luckily, I didn't drop the pizza slice, and was able to transfer it to my right hand. But I couldn't reach far enough under the passenger seat to find the Mars Bar while steering and holding pizza with one hand. I think the Mars Bar probably melted.
It could have been a disaster, but fortunately I keep a spare Mars Bar in that little vertical cubby to the right of the centre console, between the boost controller unit and the lighter socket where the car-jug plugs in.
I only mention this to illustrate how important careful food management is to the safe operation of our performance vehicles.
Mars Bars Before And After An Oil Change
Edited by Darkmeat
captioning the picture
  • Like 1
Last time I was in Scotland I asked at the local chippie (chip-shop) for a slice of pizza and she took a slice off a stack and dropped it into the deep fryer with the chips and the cod.
No wonder Scots have the highest heart attack rates in Europe.
Wis' ye could replace arteries wi' braided lines.
  • 4 weeks later...
I dont know is this right topic. but I do not want to start a new topic of this issue
But how do I remove or tighten rear view mirror? is irritating when it swings when driving and it is loose
Torx bit.
  • Like 1
  • 1 month later...
nm35 questions
how much is the diameter of the lower end of the front shock absorber?
how long is the shock absorber with the spring?
the length of the rear shock absorber is? what about the rear spring diameter and length
Spring rate of stock springs?
Keep looking for a Nismo S-tune kit.
stock suspension is way too soft for a 1600kg wagon, even worse once you fit sway bars
S-tune is 20% stiffer, awesome mod.
If you search it at RHD Japan, all the specs are there, you could easily calculate close approximates for stock rates
Edited by conan7772
more info
I'msure people have asked this before but I don't know if anyone has answeredit yet.
The M35 is available from factory with an LSD, at least in PNM35 form. For original specs go to...
http://history.nissan.co.jp/03_minivan.html
...and g33k out. C34 and M35 are both in there.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
